Page 1 of 2 12 LastLast
Results 1 to 25 of 30
Thread: confused on cai
    06 vz Maloo :)
    Oct 2010
    Lawrence
    Default confused on cai
    mmmmk well i need some clarification on cai's
    pods, panels, growlers, airboxes, otr and whatever else i have seen on the forums.
    what i want to know is why people put shit on pods and say k&n panels are the greatest then others say pods have to be enclosed to work better, then others say cai is just an expensive bit of plastic,
    i understand that cold air is better for the motor and its better for the motor if it can "breath in" easier so i guess im gonna read the same replies to this as i have on seen on other threads but just some explanation would help.... thanks
    TrikkBen's Avatar
    TrikkBen is offline Compulsive.
    BNR32
    Apr 2009
    SE, Vic
    What are you asking for help with?
    Why does an engine make more power with colder air? Simple, the air is more dense when cold, that meaning there is more oxygen per square inch of air, compared to a hot example of the same mass. More oxygen = more burnablity = more power.
    ^^ Very simple explanation.
    Ben
    There is no such thing as stupid questions, Only stupid people.
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    That's the most concise answer I've seen. And 100% true.
    Another thing to take into account is flow. Flow is everything. The air can be sub-zero but if its not getting to the motor efficiently you ain't going far.
    06 vz Maloo :)
    Oct 2010
    Lawrence
    haha sorry umm is a pod better at its job then a panel is a ss inductions one better then say mace. im definately not going to do some home job haha. i looked on wikipedia and it said exactly what you said. i dont understand why people on here have such different opinions on the matter in my head cai's are either helpful or not haha im sorry if i make no sense
    Nov 2008
    Smithton, Tasmania.
    Google "Laminar flow" I think that's spelled correctly.
    Nothing wrong with home jobs if you do your research. In fact, in most cases you can get it to work better then anything you'll buy.
    HamaTime™'s Avatar
    HamaTime™ is offline VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    A bare Pod filter in the engine bay (not enclosed) is worthless as it draws hot hair from the engine bay.
    An enclosed pod shields the intake/pod from the heatsoak/hot engine bay air, thus allowing the majority of air to come through the pod from behind the headlight which is generally alot cooler (cooler air = denser with oxygen = more power)
    A Panel filter works the same. However the problem with the stock airbox/panel filter is the flow side of things (See soop's post above)
    But this is all two and one half dozen the other ... meaning a bolt up CAI is really going to make that little difference it's not worth thinking about.
    Modifications yield their true potential when they are all paired as a combo, i.e. if you put a catback on, you've gained little, change the whole exhaust, you gain alot more.
    Think wider than just a little mod giving you some BS marketed 5kw gain or greater fuel efficiency etc etc.
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
    Nov 2008
    Smithton, Tasmania.
    Pods also disrupt the air flow, causing turbulence which will effect the MAF's ability to read the true volume of air.
    So if you use a pod, have it as far away from the MAF as possible.
    A big panel filter would work better IMO.
    VT Acclaim Wagon
    Oct 2008
    soop, not trying to hijack the thread but is the standard otrcai on the VT no good?
    Nov 2008
    Smithton, Tasmania.
    IMO no.
    Run it on the dyno, then pull it off and run it again.
    I'd put $50 down saying it doesn't do a thing.
    More again, invest in a temperature sensor and digital thermostat from Jaycar and plum it into the air intake and measure the difference in intake temps. This will tell you for sure.
    Again, I'd confidently put money on the difference being less then 5kw and/or 10degrees.
    06 vz Maloo :)
    Oct 2010
    Lawrence
    yea i got the exhaust sorted headers cats and the rest of the system, got a 69mm throttle body on rockers to put on when i get the chance it still has the stock intake tho and i looked at the mace on and a pamphlet for the ss inductions.
    so with what i have already done to my car the cai will make more of a difference
    Nov 2008
    Smithton, Tasmania.
    Nothing you'll really notice mate.
    Of course sales men are always going to tell you otherwise
    06 vz Maloo :)
    Oct 2010
    Lawrence
    i googled that laminar flow soop made sense after a few reads then reading slowly out loud hahaha
    06 vz Maloo :)
    Oct 2010
    Lawrence
    bahaha yea they always will
    what would you say to people who say that there cai gave them this and that is it just in their head like an aphrodisiac kind of thing
    Nov 2008
    Smithton, Tasmania.
    LOL, you're approaching a very contentious subject here mate.
    Personally I think its purely a placebo effect.
    I've no doubt that a CAI will influence the running of a motor but the real life effects aren't noticible to the driver. I've come to that conclusion after doing modification to lots of differet cars and motors.
    As I said before, CAI is misleading the most notiable effects will be felt due to an improvement in flow not air temperature.
    Improve everything between the airbox and the intake valve and you'll be on a winner.
  15. #15
    vs commodore
    Oct 2009
    Tamworth NSW
    All nitrous oxide does is make the air going into the cylinders more dense which gives more horsepower.Its the same with cold air,the colder it is,the more dense it becomes, which ends up making more horsepower...
  16. #16
    Nov 2008
    Smithton, Tasmania.
    Well the name says it all.
    No2
    1 Nitrogen molocule + 2 Oxygen molocules.
    Thats why you need a beefy fuel system to compensate!
  17. #17
    06 vz Maloo :)
    Oct 2010
    Lawrence
    yea placebo is the word i was looking for lol.
    "Improve everything between the airbox and the intake valve and you'll be on a winner."
    im assuming the larger TB is a start, then i guess larger diameter piping between the maf and TB is a good direction to go in???
  18. #18
    vs commodore
    Oct 2009
    Tamworth NSW
    Its not the nitrous that burns,nitrous is a non flammable gas,it just makes the incoming air more dence for a bigger bang.And I think its N20.
  19. #19
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    NOS adds O2 it is an oxidizer IE releases oxygen when its injected into an engine and heated hence why you feed petrol in with it so you dont just lean the car out
  20. #20
    vs commodore
    Oct 2009
    Tamworth NSW
    It also lowers the inlet manifold temps heaps when its released into the manifold as it turns from a liquid to a gas.
  21. #21
    Nov 2008
    Smithton, Tasmania.
    Quote Originally Posted by VUte89 View Post
    Well, I was playing around modifying inlet plenums a while back. Don't see much point using a larger TB when the internal port on the manifold is filled with casting flash and about half the ID of the TB.
    If you change the intake pipe avoid anything with corogations.
    After all that effort you'll probably still notice bugger all difference.
  22. #22
    06 vz Maloo :)
    Oct 2010
    Lawrence
    ahhh so you could have the biggest throttle body in the world but it doesnt matter if the plenum inlet is still the same size is that what you mean
  23. #23
    Nov 2008
    Smithton, Tasmania.
    Pretty much, again another thing people will dispute. Most of the time these people are the very same people that pay hundreds of dollars for "CAI" setups they could make themselves for $40.
  24. #24
    06 vz Maloo :)
    Oct 2010
    Lawrence
    it makes pretty good sense actually so if i was going to makw my own the basic rule would to be to let as much air a possible flow smoothly in and then happy days
  25. #25
    Nov 2008
    Smithton, Tasmania.
    Basically.
    Consider the air a milk shake, the intake tube a straw and the engine, you.
    How hard is it to drink a milk shake through a spiral straw?
    Before you jump into pulling things to bits good "fluid Dynamics" and have a quick read of the basic principles. From there on you're apples.
  1. im confused :S
    By saliba in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-08-2009, 02:34 PM
  2. confused.please help
    By saliba in forum General
    Last Post: 02-08-2009, 10:49 PM
  3. i'm confused
    By elegance in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 24-12-2008, 10:29 AM
  4. Confused. Need Help
    By commodorecrazy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-12-2006, 11:07 AM
  5. Confused
    By cuckoo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-05-2005, 11:02 PM
