Results 1 to 12 of 12
Thread: Ran out of fuel !
    VX acclaim II
    Feb 2011
    maroubra
    Angry Ran out of fuel !
    Hi,
    I ran out of fuel and fuelled it up with my 10 liter fuel jerry can, and its not starting anymore. Is there air in my fuel line? How can I get the air out?
    Thanks for any help!
    VR Senator
    Nov 2010
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    If you ran out of fuel and your car is facing up a hill and/or leaning to the left, 10 litres might not be enough. Try adding just a bit more fuel. Happened to me once.
    MY RIDE
    calais24/7's Avatar
    calais24/7 is offline Mucca Mad Boys
    VS Calais II 5L, 98 rodeo v6
    Jul 2009
    VX acclaim II
    Feb 2011
    maroubra
    Its a VX acclaim II and its standing on a straight road.
    I might have to mention that the fuel gauge doesn't work. I was trying to get it fairly empty to change the floater/pump in the tank or whatever needs to be changed. I guess I got it right empty:-).
    Wouldn't have to do something with that pump inside the tank, right?
    VX acclaim II
    Feb 2011
    maroubra
    good point with that blockage. Is there any way to pump out the air if there is some in the line?
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    When you turn the ignition you should hear the pump priming for a few seconds, if you can't hear it then it is probably faulty but check fuse and relay. You might need to get someone to turn the ignition while you listen at the tank, it can be a bit hard to hear the fuel pump with noisy surroundings. Sometimes a good thumping at the bottom of the tank can get them going again.
    MY RIDE
    vs commodore
    Oct 2009
    Tamworth NSW
    Maybe it didnt run out of fuel at all,maybe the fuel pump has s##t itself instead.
    VX acclaim II
    Feb 2011
    maroubra
    calais24/7's Avatar
    Jul 2009
    I had to do the same thing mate, my fuel guage didnt work so i thought hey ill change the float. Anyways got it near empty, took the tank out changed the float no dramas, in vl's the float is part of the intake pump, cause the vl has 2 fuel pumps, anyway. Put the tank back in hooked it all up, put a 20l jerry can of fuel in and no start, i started to get worried cause it was a prick of a job to take in and out. Filled up in total of about 45 litres and then it started, turns out the "Working" fuel pump/float would only work when it was half full or over. So like others said you may need more fuel. I know it sucks but typical commodore
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    It could take a bit of cranking to get it going, I would crank for at least 20 seconds. Alternatively the fuel pump may have shit itself by running dry, they don't like that.
    Ronald Reagan (1986)
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    Put more fuel in it. When I ran out of fuel in my old VX I had to put about 15L in for it to start for me.
    Plus it could take a while for it to get the fuel through the system.
  1. blockage in fuel line - appears to be fuel pressure regulator??
    By ryan1980 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-08-2011, 06:23 PM
  2. have had to wack the fuel tank to start my car!! is my fuel pump stuffed?
    By CV6Z in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-08-2010, 04:13 PM
  3. cracking open fuel tank to change fuel pump?!
    By VS5spdV6uteowner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2009, 08:00 AM
  4. fuel surge turning right? weird inst fuel readings
    By vkotis in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-10-2006, 12:00 PM
  5. fuel injected 5ltr motor setup for dual fuel
    By ma77es in forum Swap / Wanted to Buy / Trade
    Last Post: 28-05-2006, 07:03 PM
