Results 1 to 7 of 7
Thread: vt cuts out with no warning
    VT wagon
    Mar 2007
    Default vt cuts out with no warning
    after driving for a while my commodore cut out ,will start again after a while but than cuts out again , have to leave till the next day for it to run properly does any one no what it mite be thanks
    VT 3.8L Acclaim Wagon
    Feb 2011
    Narrabeen
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    You need to be a bit more specific about the vehicle you are referring to. Your ride says VR V8, your post says VT without indicating whether it's a V6 or V8. If it's a V6 then Chaps has the probable solution. If it's a V8 then the problem could be the ignition module overheating or the Hall Effect sensor in the distributor.
    vx calais superc6
    Sep 2008
    100 buk bet its cai, pretty common, ive had the same in my vx , not to expensive either
    vx calais superc6
    Sep 2008
    Mick1988's Avatar
    Mick1988 is offline W.A. Cruise Moderator
    Too many to list......
    Apr 2008
    Perth, Western Australia
    Could be crank angle sensor but this problem can also indicate a blown head gasket or cracked head.
    VX2 Executive Sedan - 3.8L Auto (for now)
    VT SS Sedan - Supercharged V6 Auto (Genuine L67 SS)
    VN SS Sedan - 5.0L 5 Speed Manual (Currently Balga spec waiting for panel and paint)
    VT wagon
    Mar 2007
    Quote Originally Posted by BlackVXGTS View Post
    Hi there,
    To answer your question, it is a 98 VT wagon (V6).
    The car only seems to cut out when the weather outside gets to 30 degrees + and has so far done it twice, once on a relative short drive, the second time was after a 3.5 hour drive back from the coast.
    As for the crank angel sensor, can I ask how long they are meant to last, as we had it replaced approx 2.5 years ago.
    Additionally the car has just recently started to 'over rev' (not sure what the technical term would be), whereby when on driving (mainly on freeways) the car will rev to 2-3 rpm without dropping back, the only way to try and correct it, is by shutting down the car for a period of time...but even doing that does not always correct the issues.
    Anyway thanks heaps to everyone for your advise.
  1. Power steer cuts out then cuts back in!!!!
    By fnlow1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-05-2008, 01:03 PM
