I removed my ABS module due to the common faults.
Turns out the sticker i need to get the part number on the module is missing.
How can i get this number?
i too had this problem, had a mate who actually worked at a parts store, he told me, all you need is a abs module with the same options, eg i had a calais, so all i needed was a abs module to suite a v6 with traction control, so thats all you need is the options, i spent 2 years without a working abs module, as i didnt have the numbers, then i got told that and worked perfectly since, others will say need exact numbers, but alot are going on hear say
okay so if i have an Acclaim do you know which one i should be using?
