Results 1 to 12 of 12
Thread: Air Con Problems
    Jan 2008
    NSW
    Default Air Con Problems
    Hey guys,
    I have a VT V6. I had the heater core replaced by holden about a year ago.
    Recently i had my compressor changed at the local auto electrics workshop. A few weeks ago i noticed that when i had my A/C on and the dial was either on the red (Hot) or white (Warm) there was a coolant smell. Blue (cold) was fine no smell, nice and freezing. However when i turned the A/C off, there was no smell whatsoever. Also, sometimes it would be warm/hot in the drivers footwell without the A/C or fan on??? Can anyone help my with my problem?
    Thanks in advance
    Mick1988's Avatar
    Mick1988 is offline W.A. Cruise Moderator
    Too many to list......
    Apr 2008
    Perth, Western Australia
    Sounds like an issue with your heater core. Are you losing coolant?
    VX2 Executive Sedan - 3.8L Auto (for now)
    VT SS Sedan - Supercharged V6 Auto (Genuine L67 SS)
    VN SS Sedan - 5.0L 5 Speed Manual (Currently Balga spec waiting for panel and paint)
    Jan 2008
    NSW
    Quote Originally Posted by Mick1988 View Post
    Nope not losing any coolant.
    Coast_Calais is offline sick of the idiots here
    varies
    Jul 2008
    gone
    Problem with the heater tap? Stuck on and sending hot water to heat exchanger all the time. When full cold is selected the heat exchanger is closed off so normal to get super cold even if heater tap open..
    Just a thought...
    Jan 2008
    NSW
    Quote Originally Posted by Coast_Calais View Post
    Just a thought...
    Yes i did think it may be the heater tap. Didnt know the reason behind it, just thought it might have something to do with it. Their relativity cheap so i think ill replace it and see how it goes.
    Are they easy to replace? its just a matter of taking the hoses off the old and on the new ay??? anything i should look out for???
    varies
    Jul 2008
    gone
    Quote Originally Posted by WPN-42L View Post
    Haven't done one for a VT, but have done HEAPS of VN and VP, VR's.
    No drama's, just inspect all hoses and fittings and replace as necessary , flush coolant while your at it. Bleed system properly and check for correct operation. Oh and make sure you fit it all up the right way, should only fit one way but yeah, be sure...
    Jan 2008
    NSW
    Sweet, ive got myself a weekend project!!! on the topic of coolant flush. I have a general idea but not too sure. How exactly should i go about it??
    varies
    Jul 2008
    gone
    basically, take both hoses off your radiator, so you can flush it separately, and stick a hose in and hit it hard until clear clean water is flowing...
    blow water through any and all hoses you have disconnected in an attempt to get all the gunk out... also filling from top, and blocking the bottom till it fills and letting it all run out quickly helps rid any crud....
    you'll find a std hose connector (the bit on your hose that nozzles clip into) conveniently fits the face of larger coolant hoses and radiators to make less mess...
    Jan 2008
    NSW
    Cool, sounds easy enough. Does the thermostat need to open so water can through and flush the block and do i also have to turn the car on and put the heater on??? and when filling it back up, a bottle coolant and the rest with water should do it ay??
    varies
    Jul 2008
    gone
    do the flush when your heater tap is disconnected, then you can also flush the heater core.
    DO NOT run your motor, the thermostat will stay closed but water will still pass through, just not at great speed, thus i'd flush top to bottom then reverse..
    ie, hose through top of motor, run it until clean clear water emerges, then while still filling, use your hand to block the lower hose until it fills up, and let it gush out to assist unsettle any left over bits...
    then you do revers, filling from lower hose and allowing water to flow from top of motor...
    same-same for your radiator and heater core...
    when it's all said and done, fill with appropriate mixture, and bleed any air out of your system BEFORE you start car... (heater should be in 'ON' position whole time)
    start car, and top up as necessary for first minute as air works it's way out and you bleed the system.
    Then close her up and let it pressurize while you test your heater function....
    I can also recommend only refilling with tap water only for a 'test' phase while getting things right / checking functions / sussing out leaks and when it's all good, then drop water and refill with correct mixture coolant... Just saves you wasting coolant mixture in the event you have a few attempts at rectification...
    Jan 2008
    NSW
    vs Executive
    Jan 2011
    raceview
    i had the same problem with the heat in the drivers seat .Found out that one of the gromets in the fire wall had been removed and the heat is not from the aircon but in fact from the engine bay itself.Hope this helps....
  1. Signal Problems Aand LPG Problems
    By reyyan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-03-2011, 08:33 AM
  2. VZ SS random problems starting and also lock problems.
    By alista in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-12-2010, 11:23 PM
  3. Id like to know common problems with air con in vt so i can diagnose my problems
    By dope505069 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-02-2010, 03:21 PM
  4. some problems.. help
    By faisal27 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-02-2009, 10:18 PM
  5. ignition problems or starting problems
    By Vs-AclaimII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 04:55 PM
