Results 1 to 22 of 22
Thread: Alternator Voltage Reading
    VT
    Feb 2010
    Default Alternator Voltage Reading
    I'm having a charging problem in my V6. I'm thinking the Alternator is a bit buggy.
    I think the battery is ok but I'm going to get a load test done on it this week.
    Can someone give me the Alternator Voltage reading with a Multi-meter when the cars running @Idle and under Rev's with the high beam and A\C On.
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    These readings are from the cluster display. 13.9 - 14 at idle and at revs, 12.9 - 13 with A/C and high beams. It is a V8 but will give you some idea because it should be similar to a V6.
    MY RIDE
    VT
    Feb 2010
    Can you tell me how to get it to Display the Volts ? (on a single window cluster)
    This could come in handy when traveling becasue at random times after traveling and I stop then start the car again the battery is flat
    VS V6 TwinTurbo/VT SS Manual
    Sep 2005
    Hold the Mode and Up button together while you start the car. Cycle through the menu with the Mode button.
    VT
    Feb 2010
    Quote Originally Posted by IBLOWN View Post
    ThanX Mate
    VT
    Feb 2010
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    That might not be the right V, I think there are more than 1. Try pushing the mode a few more times to see if there is another V. With mine volts is the first one to come up.
    Either that or you have the right one and the alternator is stuffed and giving you that reading.
    MY RIDE
    VT
    Feb 2010
    Just double checked and there's only one display with a "V"
    So something weird is going on somewhere.
    Trayner's Avatar
    Trayner is offline L337
    1996 Vs Commodore Acclaim, 1996 Vs Commodore Ute
    Aug 2008
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Can you get hold of a multimeter to check it.
    MY RIDE
    VT
    Feb 2010
    yeah I have one,
    with out anything running its 12.7volts which why I think its not the battery, would be good if it was would save me a few hundred on a new alternator.
    whats happening is when the cars running and I have the high beam headlights and blower fan going the Voltage slowly drops down to 12v within under a minute.
    When its reving 2500rpm+ it will come up to 13.9 I don't think its doing this all the time though becasue the other day I was driving around for over 1 1\2 hour and stopped for a few minutes at the young blokes house and went to start it again and it was dead it would only turn the motor over once.
    2000 VX Calais 3.8L Supercharged
    Jul 2006
    with a brand new alternator + battery i had 14.3v at alternator, 14.2v at battery and 13.6v on the cluster. over time i had a few dramas so i changed the reg over after 3 yrs of use. now its 14.4v at alternator, 14.3 at battery, and 13.9-14.0v at cluster.
    all at idle, no ac or lights on.
    today as is, 3yr old batt/alternator + new reg about 12.9v car with ignition off
    Sep 2005
    It will flicker if its fluctuating between numbers. The volt reading in the cluster is very sensitive but really should only be flickering after the decimal point unless its flickering between 12.9 and 13.0 or something. That would explain why you cant read any of the numbers.
    VT
    Feb 2010
    I took it for a 10min drive and it just stayed the same (flickering)
    well acutely it doesn't have a dot . at all now that your have mentioned it, Shouldn't there be 3 numbers displaying ?
  15. #15
    AUII XR8 Ute & BAII XR6
    Dec 2008
    Brisbane, QLD
    A little OT, what is your idle speed?.. It shouldn't be dropping below 12.5v at idle with your AUX gear running. This makes me think the idle speed is maybe a little on the low side, and not giving the alternator enough RPM to charge properly while idling (an alternator will only charge to a certain capacity between an RPM range).
    151 Countries, One Cúl-Báire!
    Cúl is a regretted trademark of the Cúl-Báire Co-op Pty Ltd, as are his random ramblings and associated bullsh1t
    Cúl's AUII XR8 Ute!!!... Clicky Clicky!
  16. #16
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by ])R@G()N View Post
    Yes, three digits with a dot between the second and third, assuming that the voltage is 10 or above, lower than that it would be 2 digits.
    MY RIDE
  17. #17
    VT
    Feb 2010
    Well today I went and got the battery tested and they reckon it was stuffed, So I got a brand new one and its still charging the same,
    I just had the multi-meter on it with A\C and the lights On the volts are dropping to 12.0- 11.9v after a few minutes.
  18. #18
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    who told u ur battery was stuffed? if u were gettin a reading of 12.7v on just the battery thats wat a new battery should b reading neways.
    Ur regulator on the alt needs changing as its on its way out.
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
  19. #19
    VT
    Feb 2010
    Some battery joint tested it, I think it was called redpoint
    I changed the regulator when It first started playingup.
    After having a think about it, I took the battery back and got my money back and when and brought a brand new Alternator.
    Tomorrow I'll fit it and with fingers crossed the end of these problems.
  20. #20
    VT
    Feb 2010
    Ok I couldn't wait so I when and put the New Alternator on.
    New readings
    @ Idle 14.5volts
    Under load A\C flat out and High Beam on drops to 12.5v on Idle after a few mins,
    Hopefully this is the end of this problem
    I also found out what was going on with the voltage display on the cluster
    I was holding the "DOWN" button and the "MODE" button instead of the "UP" botton "MODE" button
    ThanX All for the help
    Rep points for you all
  21. #21
    VT Commodore
    Feb 2011
    adelaide
    I have just read your post and yes it should be around 14 volts. On the older cars one way of testing to see if the alternater is stuff is start the car and then take one of the battery leads off. if the car stalls then the alternater is stuffed. The battery is only there to start the car once the car is running it makes its own power.
  22. #22
    wrx884's Avatar
    Mar 2006
    New readings
    @ Idle 14.5volts
    With all accessories on u should still b around the 13V+ mark so mayb try upgrading ur grounding points in the engine bay this will help but sounds like ur nearly there.
    Even new regs from the box can fail so it does somtimes pay 2 change them a couple times with other new 1ns on which who eva u got it from shouldnt have a problem swapping over their own brand new items.
LinkBacks (?)
  1. New Alternator, New Voltage Regulator
    By VN Commy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-09-2010, 05:59 PM
  2. Alternator Voltage
    By lufkin in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-09-2010, 11:10 PM
  3. Alternator voltage regulators
    By stocky in forum Electrical Wiring / Questions
    Last Post: 02-06-2010, 08:28 PM
  4. Error Code #15 and #16 - Coolant temperature sensor high voltage / unstable voltage
    By VSSECO in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-10-2009, 12:15 PM
  5. Where can i get a high Voltage Alternator?
    By benjiaka in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-01-2008, 09:43 PM
