Results 1 to 5 of 5
Thread: Misfiring VT Help please
    VT Berlina
    Jun 2006
    Default Misfiring VT Help please
    hi everybody,
    I have a 97 vt commodore v6 and it has recently dropped a cylinder. When it is idling, it has a slight miss, then in gear it its quite shakey.
    When I am stopped at lights there is sometimes a knock, but not always. (only in gear but at a stop)
    When I cruise between 1800-2200rpm it shutters badly and i need to keep it in 3rd gear and keep the revs up close to 3000 to keep it from shuttering.
    I have changed the leads and plugs, didn't fix it. Changed the leads again to the Blue heavy duty leads... Didn't fix it, Checked the plugs again found cyl no6 very very black so I replaced it and put the gaps to 1.2mm.
    I changed coil pack, all the vacuum hoses, cleaned the throttle body, airflow metre, fuel pump and filter cleaned the tank aswell and it is still misfiring and running badly.
    When I take the plug off the 6th Cyl it has spark but the car does not react compared to when I take off the 5th or 4th.
    Any help on what could be wrong would be awesome and a solution would be even better
    Thanks
    Anthony
    VT Berlina
    Jun 2006
    I also took out the thermostat as it was seized and took the rocker cover off to see whether there was anything irregular and nothing seemed out of the ordinary.
    No oil in water etc and no problems with the tranny.
    Mick1988's Avatar
    Mick1988 is offline W.A. Cruise Moderator
    Too many to list......
    Apr 2008
    Perth, Western Australia
    So the car doesn't react when you take the lead off the 6th plug? Try swapping the injectors between cylinders 5 and 6 and see if your fault moves to cylinder 5.
    VX2 Executive Sedan - 3.8L Auto (for now)
    VT SS Sedan - Supercharged V6 Auto (Genuine L67 SS)
    VN SS Sedan - 5.0L 5 Speed Manual (Currently Balga spec waiting for panel and paint)
    VT Berlina
    Jun 2006
    Thanks for the reply Mick,
    I haven't had time yet to swap th einjectors, but if it helps, the sparkplug comes out wet.
    This morning I took off the radiator cap and the water was foaming out the top cold. It was like when you shake a lemonade bottle and get the fizziness
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    Time to get a compression test done. It could be a burnt valve or broken rings if you are getting spark to that cylinder and your plug gets wet from fuel but doesnt fire. It could be a crook injector too that is just dumping fuel in instead of spraying a mist of fuel.
LinkBacks (?)
  1. Vl misfiring
    By Chris Black in forum VL Holden Commodore (1986 - 1988)
    Last Post: 17-10-2008, 07:57 PM
  2. misfiring?
    By vt_nutta in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-03-2007, 06:34 PM
  3. misfiring
    By ciro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-11-2006, 09:02 PM
  4. misfiring?
    By yobbo88 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-09-2006, 09:20 PM
  5. misfiring..
    By VL Berlina 5speed in forum VL Holden Commodore (1986 - 1988)
    Last Post: 30-07-2006, 11:24 PM
