hi guys, i was just wondering if you are able to run a 19psi pulley on a vx supercharged l67 engine safely without at risk of blowing something or causing damage?
can anyone help me out! thanks
VT V6 fitted with DMS gold 40mm coilovers, Whiteline adjustable swaybars & strut brace, 330mm AP racing brakes, Rebuilt 3.45:1 LSD and a Powerdyne supercharger
Check it out: http://forums.justcommodores.com.au/...-v6-racer.html
"The mind is its own place, and in itself, can make a Heaven of Hell, a Hell of Heaven."
apparently wasting my time with 97 cubic inches
milk doesnt come in 1.6 litres
my geminis
well i have 12 psi atm and i have the intercooled 25mm insulator from MACE and i was wondering if the engine will withstand the 19 psi?
but i have also port and polished my heads and opened them up with alot of other mods like cam and roller rockers..will this make a difference?
as long as the intercooler is keeping temps down youll need injectors and a tune to suit
MACE say that the 25mm insulator works like a intercooler anyway so and i also have bigger injectors anyway, however if thats the case i wont risk it and stick to the 12psi
25mm spacer is nothing like a cooler youll still be pumping extreemly hot air straight down the engine dont fit a higher boost pulley
So no intercooler? Then no chance of gaining benefit - safely or otherwise, going above 12psi.
"You want fast, reliable and cheap ? You'll find a Commodore out there that can provide any two out of those three!"
yeah youre pretty much at the point that everyone gets too with an L67 time to spend $1500 just to intercool it so you can add more boost. then the cost of pulley, injectors ,tune etc then you get to the point that you keep upping boost and gaining low down torque but no extra HP cause your getting the extra PSI just from the heat expanding the charge air not actually forcing more air in
it been proven on a dyno that ya loose power with any pulley above 10psi (without a cooler) cause of the extra heat it pull's timing or something and end up loosing kw....
but if ya got a cooler and all ya other mods pretty sure its sweet to run 19psi pulley if its tuned for it..
When you do things right, people won’t be sure you’ve done anything at all,,,,,,,,,
353RWHP L67 VS S Pack 6 Speed
Kalmaker Tuning Software N03 N04 N05 N06 N07 N08 W00 W10 W20 W21 W30 W31
W40 W41 W45 W46 W50 W51 W55 W56 W81 W85 W86 W91 W95 W96
okay thanks guys, am i able to run the 25 mm insulator aswel as the air to air plate for the intercooler?
never herd of anyone doing that^^^^^^.....think the charger will stick thru the bonnet...
