Any Help on how to fix the following.
Gear stick has to much play & movement in it.
is it natural for the front end to try jump up went revved out in 1st while changing to 2nd.
best way to fix clear coat peeling on hard top and right side guard
ABS light comes on from time to time, doesn't seem like the brakes are wrecked.
And main things to check or replace when car goes ova the 100,00km mark, or things you recommend to change.
Any help would be highly appreciated. cheers
