hi guys i just purchased a vt series 2 clubby last nite, so im new to the vt section
the right indicator flashes faster then left
on the rear front and side of the right of the car flashes fast,
do i just need new globes, or fuse ?
if anyone could help me out, i searched but all i got was clicky indicator stalks
thanks
going supercharged with comp pacies and 3inch exhuast
i'd say a bulb would have blown... there all flashing right?
If all the indicator globes are working then look to see if one is duller than the one on the other side at the same position. If someone has put a globe in that has a lower wattage than the original then that side will flash faster.
^^^ What he said, check all the globes they should all be 21watts each
While you are checking the globes, look in the fitting for corrosion. Bad earthing can cause this problem.
I had to replace almost all of my rear light fittings i kept blowing globes all the time. Took me awhile to realise why :/
as everyone else has said .. youve got a shonky globe or bad wattage globes, or theres no connection to the globes lol .. could also be a shonky flasher relay aswell. But my first guess would be the globes
thanks guys, sorry for the reply, just been flat out with my new job
the indicators were normal again at one stage and now flashing faster on left side
i will have a look for cracks and watts of the globes, thanks alot guys![]()
