Results 1 to 4 of 4
Thread: Code 19 , Loss of Overdrive
    VT 3.8ltr Berlina Next Car: VZ Calais or VY SS
    May 2010
    Default Code 19 , Loss of Overdrive
    I was Driving my Series 1 VT Berlina yesterday on the Highway
    Cruise control activated doing 100kmp/h
    the car gave a shudder and revved out to 3000 RPM, engine light came on
    so i disengaged the cruise control and slowed down to 80
    moving my gear selector back to 3rd and up to "D" and it wouldnt kick into "D"
    managed to drive about 20km home in 3rd.... each set of traffic lights it would rev out to well over 2500, even 3000 RPM at times before it would hesitate then "Slam" into gear. did this for both 1st into 2nd and 2nd into 3rd... still no "D" ( Overdrive )
    I took it easy and sometime taking a good 500 metres to gather speed upto 80kmp/h.
    I checked error codes as soon as i got home and got code 19
    Code 19 is Throttle Position Sensor stuck open.
    would this cause the trans to play up in the above way and lose "D" Overdrive?
    what should i be looking at to repair it the TPS? .. clean it or just replace with new?
    can someone supply a picture of this sensor or tell me where its located, what colour etc ?
    or would i have a problem with my cruise control module or cable, causing the throttle to stick open.
    I rarely use the cruise control unless im on the highway above 90-100kmp/h
    help would be appreciated. thank you
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    I can't say for sure but I think the transmission uses information from the TPS, so it is possible I suppose. The TPS is on the throttle body, it is black and opposite to the part where the accelerator cable connects. They are not really repairable as far as I know because they just wear out over time, just buy a new one.
    MY RIDE
    May 2010
    Cheers for the quick reply mate.
    Ill get a new TPS and put it in.
    Ill see how it drives after that.
    and yes I will reset the code 19.
    cheers
    VT SS S2 A4
    Aug 2005
    Sounds like rebuild time to me.
  1. no overdrive?
    By zskinner in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-05-2010, 10:39 PM
  2. no overdrive vr v6 anybody help
    By holdenmanv6vrv6 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-08-2009, 07:46 PM
  3. 1st, 2nd, 3rd and overdrive?
    By Crossy_014 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-06-2009, 06:46 PM
  4. in and out of overdrive
    By 2greedy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-03-2007, 11:41 AM
  5. Overdrive
    By rave84 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-05-2005, 08:46 PM
