hi just quick question my car has abit of trouble starting but it starts but half way through everything cuts out then it starts any idea what this could be? im thinking starter motor?
thanks
Or wiring to starter motor.......
do you mean like underneth my car could be loose or the whole wiring altogether?
Sorry to bring this back from the dead, but was there any solution to this?..
I've got that issue with mine right now. Is it an issue it sits for long periods of time?.
Battery is perfect.
Alternator fully charging and tested.
Starter fine.
Wiring?.
Same as the OP. Turns then almost turns everything off then it comes back and kicks over and starts.. When i go into - is it "factory mode" and try start the car it will shut that mode off and go back to normal like its been exited?.
Originally Posted by Yoda
