Results 1 to 8 of 8
Thread: [VT-VX] 3.8L Ecotec Engine Bay Labelled
    VX II S-Pack
    Aug 2010
    Victoria, Melbourne
    Default [VT-VX] 3.8L Ecotec Engine Bay Labelled
    Hey guys, I've started labeling my engine bay to get a better understanding, etc etc.
    So far this is all I could come up with, although there are a few more things but I wasn't 100%.
    If you could take this pic, add a few more things to it; that would be much appreciated.
    vt s pack
    Oct 2010
    brisbane
    starters- "break fuild" thats the clutch master cyliner
    and flash tube container? wtf is that?
    there all your mains things but
    black thing behind that- theres 3 of them, there ur coil packs, and dfi mod is right under that.
    and alternator is other side of the hose from the coil packs, the belt runs around it.
    VX II S-Pack
    Aug 2010
    Victoria, Melbourne
    Ah yeah how could I forget alternator and coil packs, thanks mate.
    Flash lube is for gas converted cars, it's not necessary to have it topped up but it protects valve seats, cleans injectors and apparently increases fuel economy.
    VT Calais
    Mar 2009
    SA - Victor Harbor
    black module to left of ABS is Cruise Control, 2 hoses to right of ABS are heater hoses, in front of your flash lube is water pump, square thing directly after your airbox is MAF sensor, there is plenty of stuff just depends on how much detail you want to go into, at end of top radiator hose is thermostat housing in front of plenum, maybe mark that for bleeding system
    VX II S-Pack
    Aug 2010
    Victoria, Melbourne
    Thanks for your good descriptions lufkin, just updated it. As detailed as possible would be perfect.
    VY SS
    Jun 2006
    Albany
    How about the dip stick lol, and maybe get rid of "induction" and put throttle body next to the plenum
    VX II S-Pack
    Aug 2010
    Victoria, Melbourne
    VT Calais
    Mar 2009
    SA - Victor Harbor
    Quote Originally Posted by VX Appeal View Post
    Lol dip stick is not so important, thanks though
    It isnt? you have powersteering fluid marked, radiator cap, coolant, flash lube, wiper fluid, all these fluids marks, and leave out the most important, engine oil?
  1. engine swap from vs ecotec to vr s/wagon(non ecotec)
    By gumby05 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-05-2010, 06:33 PM
  2. Are only Commodore drivers labelled hoons?
    By ClairBear in forum The Pub
    Last Post: 29-11-2008, 09:21 AM
  3. Halal Labelled Foods
    By minux in forum The Pub
    Last Post: 25-11-2006, 03:40 AM
  4. VZ Engine Bay Labelled Photo
    By Gobbles in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 25-11-2004, 07:04 PM
  5. VZ Engine Bay Labelled Photo
    By Gobbles in forum VY Holden Commodore (2002 - 2004)
