Results 1 to 14 of 14
Thread: VX (2001) Cranking but not firing
    VX Commodore V6 Supercharged
    Feb 2011
    Cowra
    Default VX (2001) Cranking but not firing
    Hi guys, a little history
    Car had been running faultlessly, have owned car since new. Took car into tyre & battery place to get a new battery installed. While mechanic was changing battery the disconnected battery wire sprung back up and arked on the old batteries terminal. He installed new battery and car started first go.
    Three weeks later, got into car, car cracked but did not start. Tried a few times with the same result. After @ a minute or so car started normally and done so for around 2 weeks when it did the same thing again. Same scenario after trying to start a few times, removed key, left for a minute, inserted key and car started first go like there wasn't a problem before.
    Could the mechanic have spiked the engine computer or some other items that could inhibit the car from starting?
    Ken
    Claudy's Avatar
    Claudy is offline French Com
    Manual Gen3 VT SS + V6 VT manual turbo
    May 2006
    Perth, Two Rocks
    Feb 2011
    Cowra
    Thanks for your reply. No I do not think it is the fuel pump. Fuel pump flows have been checked and filters cleaned recently.
    The car does not appear to be starving for fuel at any other time.
    Claudy's Avatar
    May 2006
    Perth, Two Rocks
    VT Commodore
    Apr 2008
    Good chance it's the CAS (crank angle sensor). Mine did the same thing. It progressively got worse till my car wouldn't start and I had to get it towed.
    MR_VX's Avatar
    MR_VX is offline Forced to be Fast
    VX S pac SII Raptorcharged
    Mar 2009
    Townsville, Qld
    wheres the CAS located?
    Check out my ride here >>>>My VX Raptor
    say NO to chev badges
    Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
    For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
    Claudy's Avatar
    May 2006
    Perth, Two Rocks
    Just behind the harmonic balancer it uses the little metal blades that are part of the balancer.
    Gen3 6spd Manual VT SS
    VT V6 Manual turbo
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    Quote Originally Posted by Claudy View Post
    lol ok next question, wheres the harmonic balancer located lol
    WK Statesman V8
    Mar 2010
    it's the CAS it's common for holdens to have it go at any time over 100000Ks
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    well i havent got to a 100,000kms yet so im alllllll gooood
    Claudy's Avatar
    May 2006
    Perth, Two Rocks
    Haha balancer is the big pulley at the very bottom the motor at the front the motor, that's the pulley that runs off the crank and runs all the accessories that are belt driven such as Aircon, power steering water pump and alternator
    VT V6 Manual turbo
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    arr got ya now. ill check it out
    Vx Calais Gen 111, Vz Berlina Wagon and 1948 GMC
    Feb 2011
    Mate has a Clubbie and the fault was in the Key not turning the imobilizer off intermittent fault
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Is the immobiliser turning off, that is, is the security light in the mode switch not flashing ?
    MY RIDE
  1. Vy SS Ute - Not cranking
    By fr1day_vt in forum VY Holden Commodore (2002 - 2004)
    Last Post: 14-01-2011, 04:46 PM
  2. VK, cranking but no go????
    By zaczac in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-07-2010, 07:46 PM
  3. 97 VS Commodore Cranking but not firing
    By FstStig in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-01-2010, 01:34 AM
  4. Cranking but Not Firing
    By r_i_d_a_h in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-12-2007, 04:25 PM
  5. 5L cranking time before firing
    By V85000i in forum General
    Last Post: 17-10-2007, 05:51 PM
