Hey guys!
Coming back to my car after going to the shops and now the remote on my keys don't work? Both keys do it! When I use the key in the lock they all work but this has just started to happen! Any ideas? Cheers!
Try holding the remote close to the middle of the bottom of the windscreen and see if that works. Mine occasionally would not work unless I did that. If that doesn't work then possibly the BCM is faulty or the sensor that is in the centre of the dash near the windscreen.
MY RIDE
And before you pull everything out, check the relevant fuse under the steering column. This happened to me last week. One 15amp fuse later all's well again
