Results 1 to 6 of 6
Thread: alternator
    vx berlina s2
    Oct 2010
    adelaide, south australia
    Default alternator
    hey all i need to change my alternator so i thought i would do it my self is there anything important i need to know besides loosening the belt ?
    Hangman's Avatar
    Hangman is offline Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    Disconnect the battery before attempting to remove the wires off the back of it.
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by kyriacandro View Post
    Unless a bearing has gone most of the time just the voltage regulator needs changing.
    MY RIDE
    vx berlina s2
    Oct 2010
    Yeah I know about disconnecting the battery and all. But is it just the one bolt I have to loosen to loosen the belt ? Or do I have to undo more of the pulleys?
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    There are three bolts holding the altenator on. You don't have to loosen any bolts to remove the drive belt, only fit a socket or ringy onto the bolt head holding the tensioner pully (just below altenator) and pull it towards the drivers side of car against the spring tension. This will make the belt go slack enough to slip it off.
    vx berlina s2
    Oct 2010
    thanks for all that guys i ended up doing it today after work once i started it it was pretty self explanatory really was pretty easy in the end thanks for all the replies and help
  1. [VB-VK] Removing Alternator brushes from a VK w/out removing alternator.
    By Pie-VK in forum Holden Commodore How-To's
    Last Post: 15-02-2011, 12:05 AM
  2. Is It the alternator?????
    By deenpete13 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-04-2010, 10:36 AM
  3. I need a new alternator.. What if....
    By PUSHIN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-04-2010, 01:03 AM
  4. Alternator not charging, no alternator light
    By 5L fury in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-03-2009, 05:55 PM
  5. vt alternator.
    By scozzman in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-04-2006, 09:05 PM
