hey guys!
just started raining in sunny ballarat and ive got water driping down from just above the accelerator! Any suggestions as to where i should start looking to plug it? Any help would be great as my car is filling up with water!
windsreen seal
get a air compressor with a triger thiing on it and get a mate to use it around on the inside of the glass and u stand and listen for air outside the car! hope it makes sense and helps
just park it inside till you fix it
Just run a hose over the car around the area that the leak's coming from (drivers side) and you'll be able to see the water dripping in.
Places to check:
Windscreen
Mirrors
Door Membrane (the plastic sheet people usually rip out when installing fully sick speaker systems)
Originally Posted by Reaper:
Originally Posted by Jecs:
Think I found it! A crack in the rubber that sits at the bottom of the windscreen! Blutak has seemed to have fixed it for now!![]()
Turns out blu tak didn't fix the problem! Would a windscreen guy be able to fix this kind of thing for me? It's defininlty coming through there! Dripping just above the brake pedal now :S
Took it to obriens and for $80 they took the windscreen out and re-sealed it! problem solved![]()
