my 99 vt has a short in the main f/l can anyone tell me what that fuse runs
That's the main fuse. I've heard of an earthing problem with ABS / Traction Control module causing this fault.
VX2 Executive Sedan - 3.8L Auto (for now)VT SS Sedan - Supercharged V6 Auto (Genuine L67 SS)VN SS Sedan - 5.0L 5 Speed Manual (Currently Balga spec waiting for panel and paint)
thank you but where is the abs traction control module located and can i just buy a new one
You can but it's not always the module usually the wiring involved with the module. The ABS/TC module is above your driver's side wheel arch in the engine back with about 6 metal brake lines all bolted into it. It's MUCH easier to check and test the wiring than wasting money on a new unit you probably don't need.
thanks again will check it out and let you know how i go so bloody frustrating
