Results 1 to 15 of 15
Thread: Will this work! VS TO VT???
    holden91 is offline Kickin it sideways
    Vs series 3 ute, ve berlina and a eh wagon
    Mar 2010
    rockhampton queensland
    Lightbulb Will this work! VS TO VT???
    hey i have a vt with a blown motor that i got for cheap, was just wounderin if a vs v6 will go straight into it as ive worked it?? yay or nay???
    VS Series 3 5spd ute, with a worked v6 ecotec
    MR_VX's Avatar
    MR_VX is offline Forced to be Fast
    VX S pac SII Raptorcharged
    Mar 2009
    Townsville, Qld
    ive read on here that you cant put a motor from an older car into a newer car, altho it is the same motor they could work it out with ur engine number. but by looking at it i dont think u would even no. altho i might be wrong. someone will correct me if im wrong tho
    Check out my ride here >>>>My VX Raptor
    say NO to chev badges
    Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
    For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
    Mar 2010
    yer thats wat i was thinking, there the same motor and everythink else seams to be the same. mite have to drop it out and drop the vs into it and see how i go. also i have a 5spd out of the same vs would i have to do there as the vt is auto. computer and wiring and pedals is all i could think of
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    You will have to change your inlet manifold over as the VT's have a EGR valve and also only a Temp sender and sensor in one. Apart from that its just a drag out and drop in
    If it's not a Symptom its not relevant, and if its not relevant I don't care!
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    just block the EGR off. Check the tail shaft will fit???
    Mar 2010
    cheers fella's, ill let u kno how i go
    FstStig's Avatar
    1993 VR Calais
    Sep 2008
    Tailshaft wont be a problem because he wont need to change the gearbox. Easier to change the Manifold then block off the egr because you would have to block it off at the exhaust as well.
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    not hard. i made 2 plates up out of alloy to block both sides on in 15 mins.
    FstStig's Avatar
    1993 VR Calais
    Sep 2008
    Depends on how well you are with metal and welding I guess.
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    aha i had a grinder and a file to do the job lol
    vx custom 600RR
    Oct 2010
    if you're just using the engine into the VT where's the issue same engine, right?
    commodore
    Aug 2009
    australia
    it will fit but you will just have to swap a couple of parts over from your old motor, i did an engine change a couple of weeks ago putting a vt motor in a vs so if it works the other way around it will work in yours.
    Mar 2010
    thanks for all the help, watd u have to change?
    FstStig's Avatar
    1993 VR Calais
    Sep 2008
    Just this ^^^
    Edit: No this can't be done legally. You can't put an older engine into a newer car even if it is the same engine.
  15. #15
    commodore
    Aug 2009
    australia
    i just changed the inlet manifold and all associated gear on it rest of the engine is the same.
  1. Speedo/alert won't work - replaced cluster, still won't work
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-05-2011, 10:33 AM
  2. VR 1994 Indicator doesnt work (Hazard lights work)
    By rester in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-09-2010, 01:40 PM
  3. Speedo/alert won't work - replaced cluster, still won't work
    By VS Omega in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-02-2009, 06:54 PM
  4. SWAP: My work for your work!
    By thisispete in forum Swap / Wanted to Buy / Trade
    Last Post: 20-11-2005, 06:55 PM
