Results 1 to 9 of 9
Thread: new starter motor issue
    VX berlina ecotec/ vy ss ute
    Sep 2009
    Angry new starter motor issue
    hey i just put in a new / remanufactured starter motor from sprint auto when i turned the car on it sounds like the gear on the starter motor gets cought on the fly wheel on the way out!! do i take it back or is there something i didnt do right any help would be great thanks
    VX 'S' S1
    Apr 2005
    South East,Victoria
    When you took out the old one did you notice if there was any shims between the starter motor and the engine ? If there was you need to use them when fitting the new one to retain the correct clearance
    Sep 2009
    I didnt notice anything, i rang sprint back up and they said something about my flexplate/ flywheel could be worn?
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    is it a squelling noise? but only when you start your car when its cold?!?!? thats your flywheel
    Sep 2009
    nope does it every time i start the car, it sounds like when your cars on and you go to turn the key again thats what it sounds like!!
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    Perhaps the pinion sprag clutch is faulty? ..Could have been not detected when starter was recond, and put back in service. Bloody hard to detect out of vehicle.
    vx custom 600RR
    Oct 2010
    loosen the bolts and then do them both up by until they are hand tight as best you can, make sure it seats flush
    then tighten them up
    Sep 2009
    i think it may be faulty too but if i take it back they need to send it away to get it tested :@.
    i will give it ago tomorrow oska!
    Sep 2009
    Problem solved faulty starter
LinkBacks (?)
  1. Possible Starter Motor Issue??????
    By matty69 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 09-01-2011, 07:37 PM
  2. new starter motor issue
    By budgieVH in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 13-03-2010, 07:10 PM
  3. Does this sound like a VS starter motor issue?
    By existentialist in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-11-2009, 07:27 PM
  4. [VIC] WTB Starter motor to suit VC Blue motor 202.
    By Drewie in forum Swap / Wanted to Buy / Trade
    Last Post: 11-05-2009, 01:09 PM
  5. will a manual box starter motor fit on a auto box motor?
    By lil_oneblue in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-09-2007, 05:17 PM
