Hey Guys!
Seems a new day a new problem!!
Today, while driving to work, i noticed a clicking noise, that similar to your indicators comign from under the dash...sounds exactly the same as if i had my blinkers on but it wasnt in any form of pattern just randomly going fast and slow and stopping then starting again. When this happens my blinkers are not flashing so im stumped to what it could be?
Any suggestions!
Hey Gimpy
Mine does the same, drives me nuts. From all reports, it probably means the indicator stalk has had it. About $60 from Holden. But check your indicator relays under the dash too, make sure they aren't stuffed.
indicators are working fine but gonna have a hunt under there tonight!
I had same problem it actually came from indicator stalk, when it makes noise try wiggle to stalk. Don't let it happen too long coz someone on here had it start a fire in the car. Mine started smelling like burnt plastic from makin noise for ages, same thing, indicators don't come on but makes noise. I took out the blinker box so that it didn't start a fire till I got a new stalk off eBay for like $50
Gen3 6spd Manual VT SS
VT V6 Manual turbo![]()
So replace the indicator stalk ya reckon? orite ill give it a crack! im going to the wreckers tomorrow for some other items, might pick one up then!
Common fault! The grease in the indicater switch goes a 'bit cheesy' and a trace of copper worn from the contacts gives an electrical path for a small current to activate the indicater solenoid (clicking sound)
Replace the indicater stalk, it's very easy, step by step instructions are here (somewhere) on this forum. Others more cluey will be able to find it and do the post?
Haven't you seen that repco/autobarn/supercheap ad? (i forgot which one)
it's the two bolts you left in your ash tray!
Hahahaha! Oh trust me I checked! Pulled the dash out of my vn once coz I could here a rattle! Was a little bolt in the glove box!
Sarted doing it again this morning, so had a wiggle od the stalk and it stopped it! off to grab a newy! Thanks guys!
Think I changed my flasher unit a few years ago on my VT, that fixed it..
blokes at holden told my old man when he went in it could also be a dogey globe causing it? might go through and check my globes before i pull my car apart!
In your case, I doubt it, as you said that "wiggling the stalk" stopped it. Thats the classic sign of a knackered stalk!
Lets know the outcome.
cheers
Pablo
