Results 1 to 10 of 10
Thread: VT fuel pressure regulater
    99 VT Commodore
    Mar 2011
    perth wa
    Default VT fuel pressure regulater
    Hi could someone please tell me where to locate the fuel pressure regulater on my 99 VT & or how to replace it.Thanks heaps
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    The fuel pressure reg is located on the back of the drivers side fuel rail. The return fuel hose back to the firewall is connected to it. I cant remember for certain, but of the VT-VY ecotecs which run the gold coloured steel fuel rails, I think the Vt was the model where the reg is sealed in this and is not removable. If this is the case, A whole new fuel rail is required in order to replace the reg. If im wrong and in fact it was one of the later models, then where the fuel return hose goes into the reg there should be a large black clip which locks in perpendicular to the reg housing to hold it together. Remove this clip to disassemble and remove the reg.
    If its the first option, then you'll need to remove the plenum chamber first to remove the fuel rails. If the second option, it can be done with eveything in place without removing anything else.
    Hope that helps!
    VX commodore wagon
    Mar 2011
    collaroy , sydney
    just read your post , i don't know which option I can take up to replacs my fuel regulator . How do I identify for certain which is the right option to replace the regulator ? Also , what are the symptoms for a faulty regulator ? can they be tested ? regards Paul
    VY Executive S2/ VY SS 6sp
    Jan 2011
    Western Australia
    why do you think your reg needs replacing? offen if you have a fuel pressure problem it is your pump. as to replace a new fuel rail
    VX commodore wagon
    Mar 2011
    collaroy , sydney
    hi there , thanks for replying , can u explain how 2 replace the fuel pressure regulater on my VX . What looks like the regulater is part of the fuel rail !!!! this has me stumped .
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by paaljala View Post
    I explained in your other thread.
    MY RIDE
    Jan 2011
    Western Australia
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by Burnout124 View Post
    the fuel reg is part of the fuel rail you need to replace the whole rail
    It's held in by a circlip (snap ring) on the big end of the regulator.
    MY RIDE
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    My symptoms were when it was meant to be off, fuel was still coming through a tear in the diaphragm inside the regulator.
    vt commodore
    May 2011
    australia
    Hey there i also have a 99 vt commodore and atm it wont start a mechanic said it could be this fuel regulator based on symptoms. last few days it starts but it takes a bit to get the fuel through i replaced the fuel pump and filter with brand new ones a few days ago and today it wont start at all it turns over but wont start now. could it be the fuel regulator?
  1. High Fuel Pressure - Bad Fuel Economy?
    By Goldie87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-10-2011, 11:23 AM
  2. blockage in fuel line - appears to be fuel pressure regulator??
    By ryan1980 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-08-2011, 06:23 PM
  3. fuel pressure
    By cobba_355 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-09-2010, 01:15 AM
  4. fuel pressure
    By tiersum in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-08-2010, 07:01 PM
  5. Fuel Pressure Regulator - Poor fuel consumtion
    By Chuckster in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-11-2008, 03:49 PM
