Results 1 to 17 of 17
Thread: VT Acclaim wagon power windows!
    GIMPY1's Avatar
    GIMPY1 is offline Bass Slappin Mag Designer
    VT Aclaim Wagon
    Dec 2007
    Ballarat
    Red face VT Acclaim wagon power windows!
    Sorry if this has been coverd 1000000000 times! i spent all morning searching and could not find anything relevant to me!
    A few years back, dad salvedged a bunch of power window regulators, swicthes, console switch & door trims out of a VT clubsport.
    Just wondering (minus the back door trims) if everything else should bolt in alright, and being an acclaim, which had factory option power windows, would i need any extra wiring as dad didnt grab that!
    Any help would be great!
    Quote Originally Posted by elmaso View Post
    maybe the guys really wasted, like 24/7, you know how booze can some times lead to hookin in with some fugly chick, well thats probably what happened with him and the car.
    GIMP Mobile V2.0 - In Progress
    VS V6 TwinTurbo/VT SS Manual
    Sep 2005
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    When I had my VT Acclaim wagon I installed power windows and the only wiring that wasn't already there were the door looms. The door looms are different in the series 1 and 2, series 2 are the same as VX. I have a set of door looms for a series 2 if you are interested.
    MY RIDE
    GIMPY1's Avatar
    VT Aclaim Wagon
    Dec 2007
    Ballarat
    great thanks! just wanted a llittle bit of insight before i rip stuff appart! i might pull ot the lower section of the dash tonight to see if the plug is there for the main switch!
    GIMPY1's Avatar
    VT Aclaim Wagon
    Dec 2007
    Ballarat
    thanks accentstencil! im not 100% sure what series my car is (pretty sure series 1) but ill get back to you! Out of interest, where do the door looms need to be run too....the BCM? infact where is the BCM? lol
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by gimpy21 View Post
    The door looms run from the body through the doors. The BCM is up behind the dash on the driver's side but you won't need to access it.
    If you have a series 1 the looms unplug at the body and if you have a series 2 the will be a rubber grommet at the body and a connector behind that.
    MY RIDE
    Mick1988's Avatar
    Mick1988 is offline W.A. Cruise Moderator
    Too many to list......
    Apr 2008
    Perth, Western Australia
    If your car has ABS the wiring will be there. ABS is standard on the Acclaim so it will be there. However you MIGHT need to cut two wires off the BCM connectors and solder them in. You will need to change the four door looms which are easy to replace. As said above, Series 1 is different. You will need to change all four door trims to get rid of the holes where the cranks used to be.
    VX2 Executive Sedan - 3.8L Auto (for now)
    VT SS Sedan - Supercharged V6 Auto (Genuine L67 SS)
    VN SS Sedan - 5.0L 5 Speed Manual (Currently Balga spec waiting for panel and paint)
    vt s pack
    Oct 2010
    brisbane
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by Mick1988 View Post
    I didn't need to do that, just door looms, relay and fuse and it was right to go.
    MY RIDE
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by thekid93 View Post
    this switch for the bcm to door loum?? where would that be in the vt s1?
    Not sure what you mean by that.
    MY RIDE
    vu maloo
    Jan 2011
    donr worrie about the bcm,, as longs its a mid or higher,, if you have a series 1 vt,, you need the doors looms with the white plugs.
    Mick1988's Avatar
    Apr 2008
    Quote Originally Posted by accentstencil View Post
    Acclaim has a MID BCM which can handle express down for the driver's window. LOW BCM you need to chop and solder the wires. I had to chop and solder in my VT Executive Wagon which is a MID BCM but from memory the spot for the power window relay didn't have any contacts in that car which meant it wasn't interacting with the relay. Might have been a different wiring loom even though it was the same BCM.
    GIMPY1's Avatar
    VT Aclaim Wagon
    Dec 2007
    Ballarat
    Well seems I'm in luck guys, checked all the relays and fuses for power windows and sockets are all there all wired up. Also pulled out the dash and found the plug for the main block of switches! Now, are the power window motors same in sedans and wagons?
    vt s pack
    Oct 2010
    brisbane
    i mean, so where abouts do i find the other end of the loums for the regs in the door?
  15. #15
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    At the end of the rubber boot that goes from the door to the body.
    MY RIDE
  16. #16
    Mick1988's Avatar
    Apr 2008
    Yes. Everything is the same in the doors from the bottom of the window down. You can even use sedan door trims on a wagon.
  17. #17
    GIMPY1's Avatar
    VT Aclaim Wagon
    Dec 2007
    Ballarat
    Smile
    Mick...if your telling the truth thats unreal!
  1. How to put power windows door on non-power windows car?
    By deXtrous in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-04-2010, 05:35 PM
  2. Options..power seats... power windows??
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-01-2010, 06:01 PM
  3. Power windows from Berlina to Acclaim
    By FstStig in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-10-2009, 08:11 PM
  4. 96 VS acclaim series 2 = Power windows??
    By futronix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-04-2006, 08:35 PM
  5. Can you install power windows on a VR Acclaim
    By Pete284 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-01-2006, 06:09 PM
