hi im thinking of buying my mates written off vn v6 manual with the t5 gearbox i wondering whether i can use the gearbox slave cylinder etc to convert my vx ( bell housing bolt pattern , tailshaft spline , x member ??? will it all match ) i will b buyin a new hd clutch can i use the vn flywheel ? and wat about the ecu side of things the car will b used as a burnout car so if i can keep the vx ecu n it will only log an engine code im not worried . any info or help would b much apprieciated thanx
VX's use the newer getrag. The T5 would bolt up and should work in theory but not sure how you would go with tail shaft and bell housing
VX2 Executive Sedan - 3.8L Auto (for now)VT SS Sedan - Supercharged V6 Auto (Genuine L67 SS)VN SS Sedan - 5.0L 5 Speed Manual (Currently Balga spec waiting for panel and paint)
