Results 1 to 5 of 5
Thread: VT/VX calai footwell light
    Noy
    Noy is offline
    VN SS 5.0
    Oct 2006
    Default VT/VX calai footwell light
    hey guys, just recently brought a VX calai and have just noticed my drivers side footwell globe doesnt light up. Im thinking its the globe itself but am unsure as of yet as the globe doesnt seem to "clip" into anything but that plastic bash plate.. cheers
    EDIT: just did some playing around with the globe, when I put the globe in its correct spot it doesnt work, although when I hold it in a certain position the light will come on, any ideas?
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Thats correct, the globe holder is only held in by the plastic plate you're referring to. From the top side of the plate, it drops in the hole and then a slight turn to lock it in. The globes can be removed though without having to remove anything else. They're a T10 wedge so just hold onto it and pull straight down. You'll probably have to give it a bit of a wiggle from side to side also as they can be a little tight.
    As for the light working intermittently, could be one of two things... Either the globe is dodgy and hasn't quite fully blown (try another known working one to confirm this) or the metal contacts on the globe itself where they fold over the glass and not quite in the right spot and are not properly contacting in the globe holder. You may have to flex the contacts on the globe out a little just to make sure they're getting a good contact inside the holder.
    Hope that helps.
    Noy
    Noy is offline
    VN SS 5.0
    Oct 2006
    globe is fine, but when I put it in place and lock it the light does not work. Though when I hold the globe onto the contacts it works, so seems the contacts are out of whack im guessing.
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    yeah it'll b the contacts. either pry the globes contacts away slightly or in the globe holder itself close the contacts a tad so all of it can make full contact. Globes r a pain in the ass 4 a number of reasons, just another excuse 2 go LEDs lol
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
    VT Berlina
    Jan 2011
    Bundoora, Vic
    agreed wrx884, led's are the way to go anyway, nothing about a globe beats an led.
  1. courtesy light wire for footwell lights.
    By jasnos in forum Electrical Wiring / Questions
    Last Post: 26-08-2010, 07:12 PM
  2. Interior light, footwell, boot release vn commodore
    By vnsmanual in forum Electrical Wiring / Questions
    Last Post: 13-10-2009, 10:45 PM
  3. Where is the footwell light on the Passenger side of a VR Calais
    By VRCalaisVR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-09-2009, 12:03 PM
  4. [VIC] Wtb: Vn calai garnish
    By Noy in forum Swap / Wanted to Buy / Trade
    Last Post: 21-03-2009, 04:05 PM
  5. Wrecking VN Calai 5L
    By churnit in forum Parts And Other Items For Sale
    Last Post: 24-08-2006, 09:44 PM
