Hi Guys,
Picked up an VX SS II 5.7 6 Speed manual.
The shifter seems very tight and nothcy. All gears work 100% just tight to move between them all. The old owner did a few mods to the car, so maybe one was a shifter mod?
Can I grease it up? or check it in any way?
What's the easiest way to get the console and gear shifter boot off for inspection.
Thanks
i drive a getreg 5 speed and then jumped into a clubby and also a vz sv6 with the t56 and it felt as you described.. so i'd say its normal
yeh mine is the same, i feel like u gotta put force to move from gear to gear! is there a way to loosen it up?
you can put nicer oil in it
in mine i often get 3rd instead of 1st
or 5th instead of reverse
but overall it's not a completely terrible gearbox
it just has to be that way due to the power handling, smaller weaker gearboxes for lower powered engines feel better
I have the same problem on my vt, real prick when's it's cold, Iv been told it's play in the shifter linkages,malwood has reco shifter assemblys for $225 I'm gonna get one I'll let you know how it goes
As suggested it may just need a oil change with some good quality oil, and maybe thats just the way it is, plus its done high km's.
I never ever miss the 2-3 shift thats why I thought it had something done to it. You push it straight up (dont even have to go across) and its into 3rd.
I will investigate further.
Thanks for the advice![]()
Hey guys i tried searching for this but how do you remove the factory shifter? i need too replace the shifter as the shift pattern came off mine before i owned the car and now i need a road worthy. would i be able to get one from holden at all? The car is a vx ss 6 speed. cheers.
