Results 1 to 4 of 4
Thread: need help
    Vt commordor gen 3
    Mar 2011
    N.T
    Default need help
    just bought a vt which has been sitting at a wreckers for 7 years with a blown clutch... wat things to check n do.? only reason why i got it coz the body was ok and want to transfer off my old vt to the one i bought,.... are there any ideas what i should be checking up on? it starts but a orange engine light comes on then goes off.... cheers
    2002 Vx II Spac Commodore/ 3.6L V6
    Jan 2011
    sydney
    send it to a mechanic to get a whole bumper to bumper check and get a full look over! then off those results go from there!
    VT Acclaim Wagon
    Oct 2008
    Or put a clutch kit in, change all the oils, filters and flush the brake system. Give the car a full service, plugs, leads etc and take it for a drive. you will probably find that the brakes need attention also. 7 years? Serpentine belt would need to be replaced too. while the belt is off look at the pullies. Flush the cooling system and put new coolant in. Once you have it running, check all rubber fuel and brake lines for leaks. The light you mention is probably the oil pressure sensor. 7 years is a long time to sit doing nothing. Hope it works out.
    Blown355cca's Avatar
    Blown355cca is offline Tyre Torturer
    Frankenstein "VR 666"
    Oct 2009
    Home of the SummerNats
    Where abouts in the NT are you located?
    Catch ya on the track
