hi guys i havent had my vt clubby for long now, and its started to overheat, the temperature usually sits over the half way mark, half way to 3/4 sorry if im not making sense, but even though i was driving like a grandpa it heated up to 3/4 after about 25 mins, and the fans stay turned on after the car is turned off, i read a couple threads but all i got was could be bad waterpump
im not sure why its being like that, i was thinking of renewing the coolant since the red colour has faded but i think i mite need a new thermostat
would appreciate all advice thanks in advance![]()
going supercharged with comp pacies and 3inch exhuast
over half way doesn't sound normal... are fans kicking in at half temp but it still goes over?
start with the obvious,
most thermostats stay open when they die, so lazy pump, temp sensor, or radiator more likely to blame if a flush doesn't rectify...
- check for leaks and perished hoses..
- flush entire system (including heater core)
- refill correct coolant and bleed system before load testing.
Is it losing water?
Silver Certified.
Ricey - no its not losing water mate I checked all dry never leaks
Coast calais - Ye the fans kick in, i left it in the drive turned on and fans kicked in and kept car underneath half way but when driving as low as I can go still heats, I'm changing over coolant today, by bleed system what do you mean ? I've always just done it normally on my vr never had a problem
Thanks guys ill let use know tommorow after the flushing and new coolant how it goes and also it started getting hotter quicker then before slightly
Even if you cant see leaks it may still be losing water through the overflow if the rad caps faulty or into the engine through a head gasket, check the level in the radiator.
When its hot check that top and bottom radiator hoses are both hot. If they arent you either have an air lock or thermostats stuck closed.
Silver Certified.
Adding to ricey, also check your cap is allowing the system to pressurize. Cap failures can usually be detected as a system that overheats, has no leaks but always needs water (as instead of pressurizing, it dumps water and on cool down it draws out of the reservoir) just a thought..
Also bleeding is just releasing all air from your cooling system..
i checked this morning the top radiator hose is hot, the bottom hose is cold !! and the hoses around the overfill bottle are cold to, so i think i ll go get a thermostat while flushing the coolant, is it hard to change on the ls1 ? im still new to this engine as you may be able to tell
thanks for all the advice guys
so i need to make up a gasket for it ? doesnt it have a o ring thing around it ? guessing its not sufficient then
just to be sure the thermostat is were the top hose connects to the engine ? im going of what i remember from my vr lol
