Results 1 to 10 of 10
Thread: lean exhaust... using lots of fuel but running lean????HELP!!!!
    VT 3.8 exec S2
    Apr 2009
    Mount isa, qld, aus
    Exclamation lean exhaust... using lots of fuel but running lean????HELP!!!!
    hey guys any help on this issue would be good.... now the car is a VT2 V6 2000 model. now some of u guys have probably read the other thread of mine about the idle....anyway for some reason it is running lean as, exhaust is hot like really hot, but is still using the same amount of fuel if not more than it used to??? i do not get it, i did a relearn today and cleared the codes, to see what would come back up and i got code 44 for lean exhaust, i dont get it... i shall list everything new (brand new) on this car:
    Coils, injectors, oil air and fuel filters, o2 sensors, CAS, plugs and leads.....
    wtf any ideas would be great, i am heading towards the fuel pump and/or CPS at the moment but anyone with similar issues in the past or anything that may help...Please....
    muttley383's Avatar
    muttley383 is offline Donating Member
    VR 383
    Sep 2007
    Have you got an exhaust leak before the O2 sensor giving you a false lean reading?
    muttley383
    VT 3.8 exec S2
    Apr 2009
    Mount isa, qld, aus
    VT 3.8 exec S2
    Apr 2009
    Mount isa, qld, aus
    i will double check but u can always smell and/or hear a leak, but i shall see....
    Darcon666's Avatar
    Darcon666 is offline Evil is always around you
    The Wife
    Jun 2010
    At home
    Is the engine running a little hotter then normal???
    My guess would be the IAT or MAF sending the wrong signals to the BCM and is leaning it down... but that's just a guess.
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    VT 3.8 exec S2
    Apr 2009
    Mount isa, qld, aus
    well, no vac leak, used a whole tank of 95 octane to do 200 ks... wtf is what im thinking... no one has or can pinch the fuel, nor have i got a leak, its beyond me it runs lean and even smells lean, but uses lots of fuel..... someone please shed some light or ideas on the situation please... anything at the moment is worth a go....
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Using heaps of fuel and running lean doesnt make sense.
    Are you sure your fuel guage is reading correctly? How much fuel does it take to fill when its reading empty on the guage?
    Silver Certified.
    VX Executive S2
    May 2006
    Frankston South Vic
    left and right O2 sensors mixed up, computer is trying to lean one bank but is actually making other side worse
    VT 3.8 exec S2
    Apr 2009
    Mount isa, qld, aus
    ok i can close it now.... yes fuel gauge is spot on.... not sure how the lean running comes into the findings while using so much fuel, but anyway, i come home today and i thought that well i should just check everything... so i stated at the bottom, checked left bank o2 sensor, all ok, checked right hand bank o2 sensor.... what was left, it had broken completey, i could hear ceramic cracking and crunching while undoing it and it got stuck, having finally removed it the ceramic in side was shattered the whole thing rattled, so after running around to try and find one.... mind u they all want 170 bucks plus here for one and 20 bucks freight cos no one has one, so i resorted to desperate measures, i cut the lead off the rh one and ran the wire over and spliced into the lh bank o2 sensor and presto!!! fuel economy is great, back to even better than normal, however the moral of the story is never underestimate anything that u have fitted regardless of how new it is, the two bosch o2 sensors that cost 120 bucks each not even 2000 ks ago were the culprit... so until i can get a new one, haha kind of spewin cos i threw the two old ones out, but anyway still a litlle rough on idle with no load, but the idle has improved slightly, still could be related to when the pcv valve went and filled the engine with oil and f*cked the 120 dollar platnium plugs, and it probably could have been related to the high fuel consumption for a couple of weeks until i managed to burn the oil out anyway thanks guys for your input much appreiciated
  1. Running lean
    By gsxr1201 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-01-2010, 09:08 PM
  2. Car running lean
    By .Holdon. in forum LSx Development and Modification
    Last Post: 14-09-2009, 11:03 PM
  3. running lean
    By bangers in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-10-2005, 08:06 PM
  4. Running Lean Under Load
    By riggers26 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-08-2005, 06:39 PM
  5. running lean code
    By driveberlina in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-03-2005, 11:09 AM
