If something seems too good to be true it usually is.
I got a set of stainless s extractors off ebay and have had nothing but problems fitting them.
I had to grind material off the steering colum input housing to give clearance from the pipes!
I had to grind material out of the mainfold plate so the dipstick bolt and bracket would fit!
After ####ing around with these issues and others I had it all assembled and found I could barely get the spark plug in cylinder no 2 (drivers side closest to radiator).
I have tried bending the heat shield to make it fit but the cylinder misses every now and then.
I fit a msd ignition lead that has a 45 degree bend but it touches the pipe and after five minutes of running started getting hot!
My questions are: Can I get shorter spark plugs? (what are they codes etc)
Can I get 90 degree ignition leads?
I know that there is flexible heat wrap out there but not where to get it.
Any advice or help would be appreciated!
I'll be ####in upset if I have to rip it all out and put nthe stock manifold back in!
Never buy no brand extractors!!!
