VT2 Acclaim wagon. Was driving home the other night with cruise control on. All of a sudden, car losses drive in all gears, engine revs fine but no drive in any gear. Thought it was trans so replaced but still have same problem.
So next thought is torque converter. Anyone else had this problem or able to shed any light on it?
Thanks
did you check the
Diff ???
Not the diff, tailshaft not turning when in gears.
I would be replacing the torque converter.
VX2 Executive Sedan - 3.8L Auto (for now)VT SS Sedan - Supercharged V6 Auto (Genuine L67 SS)VN SS Sedan - 5.0L 5 Speed Manual (Currently Balga spec waiting for panel and paint)
So I replaced the torque converter and still no go. Im running out of options.??
Perhaps it's an electrical problem. Considering you have changed the transmission and torque converter I don't see what else it could be. I don't know much about transmissions but I'm sure they are controlled electronically these days. Maybe it's not getting signals from the PCM
MY RIDE
This might sound dumb but have you checked the fluid level in the trans ?
