Has anyone brought 1 of these manifolds for there vt ls1?
What kinda improvements did you gain etc
And what is the quality of how its built like
cheers
~ NEW LS1/LS6 TYPHOON 96MM INLET MANIFOLD POLISHED ~ (eBay item 310297677620 end time 22-Mar-11 20:33:45 AEDST) : Cars, Bikes, Boats
Or is the street warrior 1 better?
Real cars don't power the front wheels, they lift them
unless your running a supercharger or turbo you will probably lose power thats way to big for a n/a engine. Just my 2 cents
Take it easy...But do take it...
Do not argue with an IDIOT.
He will just drag you down to his level an beat you with experience.
Some people take me the wrong way, Like smacking up Marijunna.
Yeah agreed 90+mm on an NA LS1 is way too big even if the engine had some serious headwork done.
just get an ls2 or ls6 manifold,alot cheaper & good enough for a bit of extra grunt
A pessimist is a man who thinks all woman are bad. An optimist is a man who hopes they are
i just bought 1 and a 92mm throttle body and it made 323rwhp on a 43 degree day, buy it mate looks awesome and does make a difference, the fuel rails need some hardware as its missing some stuff but only cost 60 bucks for additional hardware, well worth the money buddy
mine is a cv8 monaro too so hope that helps
^^^Dyno sheet or it didnt happen.
I reckon it'd make a great heatsoak......
Senator 300 - the CLASSY C4B!
LS1 - ETP215 @ 62cc, Comp 215/223 .602/.609 @111+3, 8.050" P/R, Morel link-bar lifters, Powerbond 25% UDP, 36lb injectors, SLP pump, Rollmaster timing chain, OTRCAI, T-56 - RipShift, 3.91:1 rear, DiFilippo 1.75" 4-1s St/St HPC coated, DiFilippo twin 3" st/st cat-back, 3" metal substrate hi-flow cats. AP-Racing 6/4-pots. EFIlive COS3 SD tune. 308RWKW. My ride:-http://www.cardomain.com/ride/389253...lden-commodore
No point changing the manifold really. Not unless you do it properly from the get go.
A decent four runner intake and tight LSA cam is the goer for an NA engine.
lot of high end turbo V8s running just the Ls6...
Forced inducted and naturally aspirated engines work very differently when it comes to choosing an intake setup.
