Results 1 to 8 of 8
Thread: unfixable breaks?
    Berlina Series 2
    Nov 2010
    Default unfixable breaks?
    so a bloke from ultra tune is trna tell me that my breaks are unfixable they will squeak no matter what. even if he does put new pads or grinds them.
    in his words " even if you get a full new break system they will still squeak"
    now 2 me that sounds realllly sus.
    i dont know much about cars just thort id ask but is this guy having me on?
    GSXR1000
    Apr 2010
    WA
    there's different methods to combat this.
    on my old R33 I used to have very squeaky brakes, I put some of that gunk on the back of the pads so that the pads didn't vibrate in the calipers.
    Wasn't TOO bad after that... helped a bit, may be worth a shot.
    I've also heard that if you bed them in when new incorrectly this can create the squeak/squeal also.
    vx custom 600RR
    Oct 2010
    here is the secret
    the part that squeals is the backing plate behind the rotor, grab it with your hand and push it back and forwards away from the rotor and you'll find that the squeal will disappear
    over time dust and road grime collects there, when you apply the brakes it begins to vibrate causing it to squeal
    just make sure the rotor is cool before attempting this
    vs commodore
    Oct 2009
    Tamworth NSW
    Ive found that using cheap brake pads can cause bad squealing.Some cheap brand pads are really bad.Ive also found that some machined discs can cause brake squeal.These days, brand new discs are so cheap,that you are much better off just buying new ones instead of machining them. Ive also found that fitting new discs give you way better brake pedal feel over machined discs.Cars that have machined brake discs fitted, always seem to have brakes that are just not quite as good as they could be..
    Berlina Series 2
    Nov 2010
    ok, im taking it into another place 2 get serviced on friday so il see what they have to say about it
    Berlina Series 2
    Nov 2010
    VX Calais s1 l67
    Sep 2008
    Perth Australia
    hey man.. there is no such thing as unfixable brakes... kinda sounds silly to me.. i had the same problem.. changed my rotors changed my pads.. and cleaned them throughout.. and they are now awesome
    hope i can help
    2000 VX Calais L67 !!!
    When you walk up to opportunities door - don't knock it..Kick that b*tch in, smile and introduce yourself.
    1DVSBSTD
    VX 'S' S1
    Apr 2005
    South East,Victoria
    I put anti squeal compound on mine when i fitted new pads , that fixed it
  1. vs v8/v6 breaks?
    By pillzor in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-02-2010, 06:50 PM
  2. When do your breaks need to be upgraded?
    By Weapon in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-11-2009, 06:29 PM
  3. VY v6 unfixable front end clunk
    By evil_monkey in forum VY Holden Commodore (2002 - 2004)
    Last Post: 07-01-2009, 10:16 PM
  4. Cigarette Breaks :|
    By 1991_Vn2nV in forum The Pub
    Last Post: 08-12-2008, 03:32 PM
