Hey guys i got a VX S (see below) i have the stock suspension on it but i want to lower it but SL's will be to low, is there a higher one like a L? and if so has anyone done it and do they have pics?
cheers Jonesy
yes there's "lows", i believe they are about fe2 height which an s-pac should have anyway
i also would like to no for mine. I was going to go SL all round. I want it about 1in/1.5in lower then my FE2 susspention. (sorry to cut ur thread) lol
what size rims are you using?
Check out my ride here >>>>My VX Raptor
say NO to chev badges
Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
arr righto. Id go 19's if i was you. I was going to get 18's but at the last min i got the 19's and happy i did. But what ever you do go for. just make sure you have the mags u want before lowering it.
Lows are available from king springs. As far as lowering ride height the difference is minimal.
97 WRX AWD
Tein Coilovers + EDFC Dampener Control - Whiteline heavy duty Rear sway bar - Whiteline Droplinks front and rear
Turbosmart dual stage boost controller
IHI VF34 Turbo - XForce 3inch TBE - Oversized TMIC - Unichip PiggyBack ECU
PPG Straight cut 1st & 2nd, Slight helical 3rd & 4th and standard fifth - HD Clutch - custom braided clutch line
02 wrx 4pot front calipers - DBA500 two peice slotted rotors - Steel braided Lines
BP98 safe tune @ 171.8awkw
SL's are what I changed my VT SS to.
It's a nice ride height. Low enough to look good but high enough to get over most bumps!
I think the drop from FE2's to SL's is something like 10mm??
Not a huge drop.
