Results 1 to 17 of 17
Thread: 1998 VT v6 only firing on 4 cylinders
    vt
    Mar 2011
    wa
    Default 1998 VT v6 only firing on 4 cylinders
    Hi Guys,
    Need a bit of advice please.
    Looking at buying a 1998 VT v6, done approx 300,000 km's, seems in good condition but only firing on 4 cylinders.
    No spark from the passenger side coil (1+4?), owner says he has changed plugs, leads and coil.
    He suspects the CAS? If this was the case would it just affect one of the coils or all coils?
    I'm hoping its the DFI but could do with some guidance.
    All input welcome guys :-)
    vt
    Mar 2011
    wa
    Update, apparently not the DFI as this has been changed.
    Would a faulty CAS cause the lack of spark on 1 coil?
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Tried swapping the bad coil for one of the others and seeing if the non-firing cylinders change?
    Ronald Reagan (1986)
    vt
    Mar 2011
    wa
    Quote Originally Posted by acarmody View Post
    Yeah apparently thats allready been done, thanks anyway.
    SBM
    SBM is offline
    VS 5Spd
    Aug 2010
    Streaky Bay
    Try it yourself just incase. I never go by what someone has apparently done. I'd also check the wiring plug on the DFI I've seen a few with a bent pin causing all sorts off troubles.
    Hangman's Avatar
    Hangman is offline Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    Quote Originally Posted by SBM View Post
    This, for all of the "done" things...
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
    vt
    Mar 2011
    wa
    Easier said tha ndone guys, can't really start stripping someone elses car down.
    I have no reason to disbelive him, he has replaced the DFI, coils, plugs and leads, infact he showed me all the old stuff.
    So the question is can a faulty CAS cause one of the coils not to spark?
    Hangman's Avatar
    Jan 2010
    From experience, I would say no, it just makes it crank but not fire, mostly when hot. That's not to say it can't happen, I'm not a mechanic.
    I'd still check the coil packs. New stuff can be faulty.
    And if this is all on a car your looking at buying, the price should be adjusted accordingly. I know I wouldn't buy a car based on how it should run instead of how it does...
    vt
    Mar 2011
    wa
    Thats my conern, if the CAS is faulty then would it stop all the coils from firing? If its not the CAS then what is it?
    Yeah the car is priced accordingly, 2k asking price, think we might give it a miss as I fear there is more wrong with it than meets the eye?
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    move the coils around and use plyers with rubber handles and pull the leads off... should tell you what is wrong with it exactly
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    Hangman's Avatar
    Jan 2010
    Crank Angle Sensor, mate
    VX Berlina
    Apr 2007
    "Crank Angle Sensor"
    EDIT: Damn, ninjaed by Hangman.
    Hangman's Avatar
    Jan 2010
    I don't reckon 2k for a vt on 4 cylinders is accordingly priced either...
  15. #15
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by Cameron P View Post
    call me stupid but what is 'CAS'?????
    Edit: I answered much to late so disregard this post.
    MY RIDE
  16. #16
    VT 2
    Nov 2008
    I know youve said it's not but it MUST be coil or DFI. DFI triggers coil, coil fires and sends spark to 2 cylinders at same time.
    If it was just 1 cylinder or 3 then it could only be DFI, but being 2 it must be coil or connection between DFI and coil. Try cleading the spade terminals of the DFI.
    If its a dud DFI, swapping coils around wont change anything. If it's a dud coil, changing the coild around will mean a different pair of cylinders loses spark.
  17. #17
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    Agreed, It can't be anything else only the Dfi, Coil Packs, Spark plug leads and Spark plugs create the spark, could check the DFI plug and wiring.
    If it's not a Symptom its not relevant, and if its not relevant I don't care!
  1. 1998 VT v6 only firing on 4 cylinders
    By greg130 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-03-2011, 02:53 PM
  2. VY 3.8 v6 running on 4 cylinders
    By jambo58 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 21-12-2009, 05:51 AM
  3. vs cylinders 6 and 4 burning oil
    By cyborg66 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-09-2008, 10:59 AM
  4. Running on 5 cylinders.
    By J_D in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-04-2007, 07:03 PM
  5. dropped two cylinders!!!!
    By HDT_aero in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-01-2006, 11:00 AM
