Results 1 to 15 of 15
Thread: Ebay parts
    VT SS 5.7
    Mar 2005
    Goulburn
    Default Ebay parts
    Is it worth it to buy the parts i need off of ebay such as
    Tie rod ends,
    Ball joint
    Wheel bearings
    As i want to replace all the steering and such parts or should i just bite the bullet and buy them from repco or somthing?
    Real cars don't power the front wheels, they lift them
    some_guy's Avatar
    some_guy is offline Donating Member
    VR SII Exec.
    Apr 2009
    brisvagus
    Whats the price difference? if yes it could be to good to be true
    Are they a store in real life? if no they may not exist at all
    Do the pictures look really pixelated? if yes they might be someone elses blurred
    You just have to be careful man.
    97 WRX AWD
    Tein Coilovers + EDFC Dampener Control - Whiteline heavy duty Rear sway bar - Whiteline Droplinks front and rear
    Turbosmart dual stage boost controller
    IHI VF34 Turbo - XForce 3inch TBE - Oversized TMIC - Unichip PiggyBack ECU
    PPG Straight cut 1st & 2nd, Slight helical 3rd & 4th and standard fifth - HD Clutch - custom braided clutch line
    02 wrx 4pot front calipers - DBA500 two peice slotted rotors - Steel braided Lines
    BP98 safe tune @ 171.8awkw
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    i wouldnt trust some random persons parts especially with steering parts.... one day you might try turn a corner and the dodgy cheap part breaks o.O
    92 vp executive v6 auto
    Jan 2010
    deception bay queensland
    just use paypal that way if it goes up #### creek you get your money back
    personally i buy most of my parts of ebay and there fine
    GSXR1000
    Apr 2010
    WA
    I bought my shocks and springs online and were fine.
    bought plenty of parts from ebay.
    You can usually tell the difference between something not so above board and something that is
    DLFHUB666's Avatar
    DLFHUB666 is offline Got Milk ???
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    I too have brought heaps of parts off ebay no problems YET.
    Take it easy...But do take it...
    Do not argue with an IDIOT.
    He will just drag you down to his level an beat you with experience
    Some people take me the wrong way, Like smacking up Marijunna.
    MR_VX's Avatar
    MR_VX is offline Forced to be Fast
    VX S pac SII Raptorcharged
    Mar 2009
    Townsville, Qld
    Quote Originally Posted by Mirkz View Post
    ^^^^ true true, i have also got alot of parts from ebay and nothing worng yet.
    Check out my ride here >>>>My VX Raptor
    say NO to chev badges
    Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
    For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
    Mick1988's Avatar
    Mick1988 is offline W.A. Cruise Moderator
    Too many to list......
    Apr 2008
    Perth, Western Australia
    Don't get the cheap #### that ships from China on eBay. There are some great stores that stock high quality parts. For example I bought an entire fuel pump assembly (with new sender, strainer, sensors and a complete new case) for $167 delivered to my door. It was a delphi unit which is what GM use anyway and I bought it from someone with high feedback.
    I reckon I would have paid $200 just for a pump in stores and not got the entire new assembly.
    VX2 Executive Sedan - 3.8L Auto (for now)
    VT SS Sedan - Supercharged V6 Auto (Genuine L67 SS)
    VN SS Sedan - 5.0L 5 Speed Manual (Currently Balga spec waiting for panel and paint)
    VT
    Feb 2010
    Always buy from Australian sellers, Do some research on the parts you need make sure there the right part.
    I have brought heeps of parts from there and have saved a bucket load of money.
    vs commodore
    Oct 2009
    Tamworth NSW
    You can sometimes pick up genuine parts cheap on ebay.When it comes to things like wheel bearings,hubs etc,I go straight to holden so then I know 100% that they are genuine holden parts..Theres new chinese VR/VS front hubs getting around cheap, they can apparently fall apart apart,I wouldnt like to put me and my familys life at risk by buying cheap dodgey parts like them hubs,just to save a few dollars,its just not worth it in my opinion... But usually if they are aussie sellers with parts that are in oz,then you are usually right.The main "cheapie" parts from places like ebay etc that Ive seen stuff up or cause problems, are ignition coils and engine sensors.Ive seen a few cheapie sensors last around 12 months or so,where the genuine part will usually last for years.Ive seen the cheap CAS- Crank Angle Sensors cause some problems.One was completely dead from new,another caused misfiring and crook running,and a couple of others I know of have lasted 12 months or thereabouts.I just bought a new CAS from my local holden dealer for $120,they cost around $50 on ebay.Most people see this difference and think that they are saving heaps,but if it needs replacing in 12 months time,them theres another $50 spent,and thats not including the fitting,if you cant do it yourself.So buying cheap parts can work out to be more expensive in the long run.
    commodore
    Aug 2009
    australia
    i buy alot of parts from ebay and have had no problems at all with most of them but i always research them first to make sure theyre not cheaper in a shop, also i would not buy suspension steering components off ebay as i personally dont trust the quality of them id rather pay a little more with that sort of thing and buy a quality trusted brand. Things like headlights, panels and interior parts i definatley get from ebay. My most recent purchase was a pair of tyres which has 80% tread they looked great in the pic and the tread amount was great but when i got them home i noticed lots of fine cracking of the sidewalls and although being the same brand/size they were from different eras and werent a matching pair like described so really theyre not a bargain even though i only paid $30 a pair theyre only good to put on the back and fry.
    Mick1988's Avatar
    Apr 2008
    Quote Originally Posted by Brett_jjj View Post
    This is why you look for a genuine GM sensor on eBay for around $100ish
    Hangman's Avatar
    Hangman is offline Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    $100 for a CAS?!?!? Ripping yourself off at that price. Most I've paid was $40 or $50 new from memory (I've replaced a few), and that's not off ebay.
    I've also used 2nd hand ones and had no trouble...
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
    dirt drifter's Avatar
    dirt drifter is offline white trash hillbillie
    VS 5L M5 VS 6L M6
    Apr 2009
    massive hole in the ground
    brand name parts i've bought a fair bit off ebay and had no worries, but i steer clear of the no-name bits. i was looking at vs front hubs on there a while ago, they were some no name thing and the ad read.. and i quote "good quality (studs will not snap off)"
    needless to say i didnt take their word for it! went to holden and got the decent SKF brand genuine hubs, would do the same with any other suspension/steering/drivetrain bits
    Quote Originally Posted by UFO View Post
    worked v8 + supercharger + dogbox = panty moistening equipment.
    4 banger turbos with bov's will just cry when they hear it, because they can never have it.
    Quote Originally Posted by GRPABT1 View Post
    Avoid cluey police
  15. #15
    Dec 2009
    Quote Originally Posted by Mick1988 View Post
    Delphi are made in China just like a lot of other Holden parts. The genuine fuel pump I bought a while back for my VN had made China on the box and the fuel pump was branded Delphi. I think the current V8's are from Mexico as well?
  1. ebay link to stuff on ebay vn vp vh range of stuff
    By Zuicider in forum Parts And Other Items For Sale
    Last Post: 03-11-2008, 04:17 PM
  2. Ebay parts - Asking for trouble?
    By feistl in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-02-2008, 07:04 AM
  3. Parts book for sale (ebay)
    By Dilweed in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 05-04-2007, 07:10 PM
  4. FS: Lots of VN-VS parts on ebay
    By lowrida56 in forum Parts And Other Items For Sale
    Last Post: 28-12-2006, 12:18 AM
  5. EXCLUSIVE!!! VE PARTS FOR SALE ON eBay!!!
    By Troy711 in forum VE Holden Commodore (2006 - ?)
    Last Post: 16-07-2006, 12:07 PM
