Results 1 to 5 of 5
Thread: vx ss temp creeping up at idle
    vx ss
    Mar 2011
    perth
    Default vx ss temp creeping up at idle
    Hey guys ive got a vx ss and ive got a problem with the temp rising at idle its fine while im driving its only when im stopped it will reach aprox 3/4
    Ive looked at the thermo fans and they appear to be comming in when the temp reaches 98deg as i checked by using the digital display on the cluster (holding the mode button and the up button and then turning the car on)
    Tho even after they turn on the temp keeps going up
    i can make the fans come on with the ac at idle and temp will still rise
    seems strange as while driving the temp will comfortable sit at 1/4 its only when at idle it rises
    any ideas guys as its got me stumped cheers
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    It's normal for the temp to rise when you are at idle because there is no airflow through the radiator. You say that the thermo fans come on when the temp reaches 98deg but it continues to rise. Do the fans ever get the temp down below half way or lower at idle? Have you checked to see if both fans are coming on or just one?
    vx custom 600RR
    Oct 2010
    mine never moves
    that's a sign the thermostat is failing it happened to me in different make of car, do it before you blow your radiator
    vx ss
    Mar 2011
    perth
    cheers for the feed back guys i ended up taking the water pump of and inspected it and the impellor was fine
    so i then checked the thermostat and found it was sticking
    i replaced the thermostat today and re fitted the water pump with new gaskets and all was good only cost me $70 so was happy thats all it was
    cheers
  1. oil temp/water temp gauge wiring
    By HUMBLZ in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-05-2011, 04:53 PM
  2. normal running temp for a VT 5L? and temp gauge..
    By mike49 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-08-2009, 12:57 AM
  3. Q's regarding Coolant Temp & Intake air temp sensor
    By Steven M in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-02-2009, 05:08 PM
  4. VN 5.0 Temp at idle
    By Noy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-01-2009, 08:58 PM
  5. Electric oil temp and water temp gauges
    By FRESH_VR in forum General
    Last Post: 02-09-2008, 04:27 PM
