to whom it concerns.. IM just a bit worried that im going to go through another VT BOX>....
I think from what i can tell i dont have much tranny fluid ..will be filling it up tonight took the car for a drive ran fine
But going from say p to r
or r to d .. it makes a loud CLUNK?
wud it be a slappy tailshaft?
we did raise the car from the diff yesterday to do some work.. just wondering if this would have anything to do with it..
Just concerned .. done some re search and is it a problem on a vt?
cheers
2000 VX Calais L67 !!!
When you walk up to opportunities door - don't knock it..Kick that b*tch in, smile and introduce yourself.
1DVSBSTD
Top the fluid up and then come back here...
cheers mate.. guess im just a bit more concerned this time as it happend to my first vt and i ended up selling it.
1DVSBSTD
Does the car jerk quite alot when you change it out from P/R or put into drive ?
Mine did this, but it would also shift hard into 1st - 2nd. Ended up just being a TPS
Check error codes perhaps as well.
Most likely just the fluid *fingers crossed *
what is a TPS?? traction something??
how can i check the code ? by crossing the wires together? on a vt? used to do it on a vs
and yeah im hoping its just the fluid.. it just seemed like there was #### all in there when i checked at lunch.. Checked several times and it seemed like there was only little traces of fluid and thats after it was hot... I know the car needs a service.. But ive been drivn it for less then a week n babying it haha..
Damm cars.. always so much fun
yeah it just feels like a BUMP or a BOLT
1DVSBSTD
TPS = Throttle Position Sensor, it's located on your throttle body.
There's a connector under the dash which you can see near where your pedals are.
You need to link pins 4 & 5 if I remember correctly, might be 5 & 6.. anyway, search for a thread by Airstrike on checking Error codes, tells you all you need to know.
Don't go swapping out the TPS unless there's a code being thrown up. Don't want you wasting money just because someone on a forum says it happened to them.
Unfortunately it could be a number of things so it's a matter of just eliminating the things one by one.
Here's airstrike's thread
Checking error codes VT/VX
well ill have a look at it tonight when i get home and figure it all out.. i must admit.. i havnt spent much time under the bonnet since i got the car
it does need a service but that wont happen for a few months due to the $ so hopefully something easyi have fluid so ill see how that goes
1DVSBSTD
UPDATE.. just to let u guys know.. Problem seems to be rectified.. car drives alot better with a top up.. was on half.. Still not used to the slappy diffbut im sure i will
cheers for all your help sorry if im annoying
1DVSBSTD
glad only a top up was required mate, a lot less effort and cheaper that way.
Wish half of my issues were like that :P
trust me mate.. this car has a few issues i gotta attend to..
still drives perfectly fine.. BUT needs a service.. as its timing is all out of wack.. and i end up using more fuel...hence my other post haha...
Cheers for ure help tho.. Guess i just gotta get used to this compared to the vs
1DVSBSTD
