Results 1 to 9 of 9
Thread: LPG problem
    P-Plater VL
    May 2010
    Default LPG problem
    hey guys, not sure if this has been posted already but i recently bought a vt berlina. it had the gas tank already installed and was working perfectly.
    i did not use the gas for a while, since i was running on petrol..
    to cut straight to the point, every time i try to change the car from petrol to gas the car stalls. it does when the car is cold, warm or hot. there is a full tank of gas..
    before i take it to a gas joint, can anyone give me a heads-up of what may be wrong?
    Jonesy484's Avatar
    Jonesy484 is offline Quicksilver Club :)
    VX I S
    Sep 2009
    Melbourne. Victoria
    Quote Originally Posted by INtensity View Post
    quick question is it when you flick the switch over or is it when your running on gas? if its when you flick the switch, from what i can work out on mine is that engine has no fuel going into it and stalls. I pull over switch the car off flick the switch then start the car up again
    Jonesy
    Quote Originally Posted by DM 55 WA View Post
    venetians make me want to punch kittens
    Special thanks to B-Roca for my new sig
    vx custom 600RR
    Oct 2010
    P-Plater VL
    May 2010
    yeah when i flick it over.. i thought it was that no fuel was getting in, but i left the car in neutral and tried to get gas into but after i revved the car it just stalled.. not i know you shouldnt start the car on gas.. could something be blocking it or wrong with the converter?
    Jonesy484's Avatar
    VX I S
    Sep 2009
    Melbourne. Victoria
    Quote Originally Posted by oska View Post
    get it serviced
    mines done like 22,000 since it was installed i should probs do that to :S
    commodore
    Aug 2009
    australia
    have you checked whether your convertor is freezing up ,it would have an icy coating on it if it is, maybe there may be a blockage in the coolant lines to the convertor.
    Jonesy484's Avatar
    VX I S
    Sep 2009
    Melbourne. Victoria
    your ok to start your car on gas, im pretty sure it is just the engine being starved of fuel, when it stalls does it make a high pitched pop?
    VT Berlina Wagon S1
    Oct 2008
    When changing over to LPG, whilst running, most vapor type LPG systems will need the engine rev'ing at or above 2000 RPM as it needs the suction to pull the vapor through the hose. On an engine like the Ecotec the hose is usually quite long and then the rest of the induction plumbing has to fill up with vapor too, about 3-5 liters ish... so the LPG has a long way to go before it hits the cylinders... without the higher revs the engine will stall before the gas gets to burn.
    VT
    Feb 2010
    I had the same problem the longer I ran on petrol the harder it was to start on gas, I have been running the car on petrol for about a tank full and then refill the gas and tryed to start it but it wasn't going to start,
    I had to put it into get fixed, they said there was a wring fault seamed funny that it was only when I ran on petrol for a time, any other time it ran perfect. anyway I did notice they ran a new earth wire from the battery to the converter.
    end of the story it cost me 118bucks and its running again, finger crossed thats the end of the problem
LinkBacks (?)
  1. 25-03-2011, 01:56 AM
  1. [VR-VS] How To: Fix the VS V6 4 Wire O2 sensor earth problem – Known Holden Problem
    By ephect in forum Holden Commodore How-To's
    Last Post: 17-01-2012, 11:25 PM
  2. VK v8 breathing problem/oil pressure problem
    By Bookanun in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-12-2010, 03:02 PM
  3. idle problem, very difficult to find problem
    By calais s2 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-07-2010, 10:51 PM
  4. Central locking Sv6 problem. this going to be a problem car??
    By philsv6 in forum VE Holden Commodore (2006 - ?)
    Last Post: 21-04-2010, 10:40 AM
  5. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
