hey guys i have a vx ss had the clutch done a few months ago ever since i have had it back its leaking motor oil from where the gear box bolts up to back of motor would this be the rear main seal or maybe the gear box not lined up properly any info would be great getting sick of oil every where thanks
Hey Mate.
Did they replace the seal when you had the clutch replaced ?
If you can, Degrease the whole area, and then you can pin point it exactly where its coming from, but my guess it is a main rear seal, its very hard to get them to ever seal again i have been told![]()
That Really does not sound good if the bolts are just spinning and not being able to do them up to seal the box. Im not to sure of the set up with the Manuals
might just seal the box with heat prof silacon hahaha might slow it down a bit lol
