Just asking a question for a mate of mine.
High beams come on and off randomly when driving along?? Anyone had this problem before? is it to do with the stalk. Thanks.
Yep, had this a couple of weeks ago... a bit embarrassing, flashing oncoming drivers unintentionally. Replaced indicator stalk with a new one off ebay, ($20) no more problem. Also fixed the right indicator not turning off automatically. Just by the way, the indicator stalk is not repairable. Like the front hubs, it is replace only.
Try this: http://cars.shop.ebay.com.au/?_from=...lk&_sacat=9800
yeah i have this problem, not very oftern but. not gonna bother fixing it.
New stalk on the way Thanks.
mines gradually getting worse, how do u replace the stalk? or do u get someone to fit it for u?
Take the steering column shroud off, one screw underneath at the rear/bottom of the shroud. Lower the column. Push the bottom half of the shroud toward you at the same time pushing the top back a little. Should fall off in your hands. There two small hooks at the back of the upper half of shroud which go into two slots at the back of the lower shroud, it is these your are trying to unhook. Disconnect the cruise plug if there is one, disconnect the main plug. There are two plastic clips on the switch base, squeeze these and at the same time pull the switch away from the column. Installation is the reverse. GMH advises that the battery should be disconnected when doing this. Airbag in face at point blank range can be very painfull.
