have asked a few poeople regarding my problem, every 2 or so weeks my battery goes flat, ive replaced the starter motor as apparently they sometimes fault and drain power, ive also checked my voltage on the alternator and it 13.9, i dont know where else to look for reason for the problem, any help would be greatly appreciated.... cheers nathan
Had the same problem a week ago once running it was running 14volt but thou the day it would go dead flat had to keep jump starting it turned out low water in battery put water in and the it died best bet check the water if its low your cell's would be ####ed you might need a new battery mate
you need a new battery.. ive had this problem before
2000 VX Calais L67 !!!
When you walk up to opportunities door - don't knock it..Kick that b*tch in, smile and introduce yourself.
1DVSBSTD
If you recon the battery is OK, take off a battery terminal and check for a power drain by hooking in line a multi meter with a 10amp setting. Could be anything from a boot lamp stuck on, to an after market car alarm, stereo amp, or what ever, quietly sucking the power.
Could also be the start of one of the alternator diodes playing up.
Agreed, Check your battery cells first, top up with water if they are low and clean off any battery acid around your terminals, with hot water.
If it's not a Symptom its not relevant, and if its not relevant I don't care!
cheers will check it out
