VT Internal Dome light
johnmic
60
Gday all, Ive recently lost my internal dome light , Ive recently changed the BCM and Computer due to other problems that with the replacement have been fixed.. the bcm and computer Ive replaced is from a series 1 and the one that was in the car previous was a series 2.. does anyone know how to get the lights working without replacing the bcm .. can the internal dome lights fixed to not go throught the bcm.
DLFHUB666
GIT 'EERRR DONE!!!
40
Nhulunbuy NT
VX SS, PX Ford Ranger XLS Dual cab
Have you tried putting a new bulb in it???
M
mwb235
Guest
I don't know what wiring you'd need to modify to get it to work. IMO you'd be better off fitting another series 2 BCM it'd be easier!
BUT if you do want to use the series 1 BCM and modify the wiring, i've attached some VT series 1 wiring diagrams that might help you (dome lamp/low series BCM/high series BCM). Please note these cover series 1 only and NOT series 2 - sorry but i don't have any series 2 digrams. The attachments are probably too small to read here (this forum limits attachment file sizes etc) if so PM me your email address and i'll send them to you.
My guess is your problem is the series 2 BCM has a timed delay for the dome lamps (and therefore different circuitry) whereas the series 1 BCM does not - but i'm not 100% sure.
I do know that when replacing a BCM, the replacement has to have the same three-digit code as the original for everything to work properly, as the internal circuitry is slightly different in each BCM. In case it helps i've attached a list of the BCM codes for VT/VX/VY.
(For those that might find it useful: There is one exception i know of - you can upgrade a VT series 1 Calais "685" BCM to a VT series 2 Calais / WH series 1 Statesman "312" BCM (both "HI" series). I did this to my VT series 1 Calais as i wanted the remote-operated deadlocking and time-delay interior dome lamp. Other than swapping the BCM, no other mods required except getting new keyheads and the PCM linked to BCM with Tech2. But i don't know if you could do this with lower-spec BCM's.)
