Results 1 to 11 of 11
Thread: cleaning throttle body
    vx
    Aug 2009
    Default cleaning throttle body
    hey guys,,,,, i wanna clean the throttle body coz its full of shit but am really facing a little of problem in there. first i was trying to remove the butterfly to clean inside and around it but the bloody criuse cable and gas cable are mounted and am unable to take out the butterfly unless i undo those to cables. plz can someone help me?..
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    The plastic clip one you just force backwards, easily done with two fingers. The metal one you just get a screwdriver under and jimmy it up. Both should come off easily.
    Ronald Reagan (1986)
    vx berlina s2
    Oct 2010
    adelaide, south australia
    Dec 2009
    Why not give that new Nulon foaming throttle boby, intake manifold cleaner a go? It's probably similar stuff tothe Subaru Upper Engine cleaner.
    Foaming Air Intake Cleaner - Nulon Products Australia
    S.T.K.E's Avatar
    S.T.K.E is offline Wiggle Wiggle Wiggle
    Holden Jackaroo 3.0TD
    Mar 2009
    Brisbane Northside
    Take the thing off, it's only 2 Nuts and use some carby cleaner. Don't make shit overly complicated.
    STKE's Ride: http://forums.justcommodores.com.au/...lais-3-8s.html
    Quote Originally Posted by Tim Smtih
    Also you could just whisper in his ear "guess what i did to your mum last night?" And walk away laughing.
    98 VT 3.8 auto
    Oct 2009
    Your only making life difficult removing the 2 butterfly screws, ensure you use some loctite 262 or similar when reinstalling the screws. Its much easier to undo the 13mm nuts that hold the throttle body on. Remove the idle speed motor & clean it by spraying a rag then wiping it, if you spray the idle motor too much it will bugger the electrics inside. dont touch the throttle position switch (too much re-adjustment required with computer)
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    You don't have to undo any of that.
    Pull undo the throttle cable, take off two nuts and soak it in carby cleaner and use an old tooth brush to clean the soot off.
    VT Calais
    Mar 2009
    SA - Victor Harbor
    when you take it off, is there a gasket that needs replacing or anything?
    Nov 2008
    Smithton, Tasmania.
    vx berlina s2
    Oct 2010
    Nov 2008
    Smithton, Tasmania.
    yeah. Just give it a good scrub with an old toothbrush.
  1. throttle body cleaning
    By Rampage in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-07-2006, 08:30 PM
  2. cleaning ur throttle body
    By cameron4518 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-06-2006, 03:20 PM
  3. Throttle Body Cleaning
    By jack.mc in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-01-2006, 01:02 PM
  4. cleaning throttle body
    By ads72 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-09-2005, 10:42 PM
  5. cleaning the throttle body
    By vpwgn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-03-2005, 04:31 PM
