I have a V6 VX and I just put in my new digital water temp gauge using the piece that goes in the top radiator hose now for some reason it isn't working right. While I'm driving the temp will sit at 40 then bounce around, but when I idle for a bit it starts to work (sits about 4 degrees lower then the standard gauge). I can't figure out why it is doing this I've tightened everything and checked the wiring and it is all good. I was thinking is there anyway I can tap into the standard gauge wiring (the digital one on the dash not the needle one) and run from that. Any help is greatly appreciated.
