Results 1 to 7 of 7
Thread: VX brake pedal went to the floor...!
    vs executive
    Jun 2010
    Default VX brake pedal went to the floor...!
    My daughter has a VX which we are currently using as a work car. All is good but about a month ago i dropped her off at home then on the way to my place, the brake pedal went to the floor, the handbrake light came on and the h/brake alarm went off. The car seems to slow a little and i pumped the pedal up a bit which helped (i drive a 1961 Land Rover so i know all about bad brakes). It happened once again then it was fine.
    We took it to the brake guy who pulled it all apart and found nothing wrong so we got him to change the fluid as a matter of course. Everything was fine and my daughter thought i had imagined it until the other day she was driving and the same thing happened only the pedal didnt go all the way. light and alarm went off, then she pumped it and soon all was good.
    Has anyone else had any similar problems and any ideas on what it could be?
    2007 VZ ACCLAIM WAGON
    Feb 2005
    St Clair
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    Either that or your abs i would be checking.
    If it's not a Symptom its not relevant, and if its not relevant I don't care!
    ashbox's Avatar
    ashbox is offline 6 speed
    VZ SS 6 Spd
    Apr 2007
    The Car
    i'd suggest finding out the fault code and then taking it from there, rather than replacing everything until the problem is solved
    Chev badges are an instant fail
    2002 S2 VX CLUBSPORT
    Mar 2011
    Melbourne, Altona
    VT 2
    Nov 2008
    For the Pedal to go to the floor without much break force being applied, then either the seal around the brake piston in the master cylinder is gone, or something is interfering with the seal.
    Piston can't be gone itself or it would happen every time. Ditto the master cylinder housing.
    Unlikely to be abs because ABS doesn't cross channels - ie Front brakes are a seperate circuit to rear. Front does 70% of braking, while handbrake is on the rear. Ergo - unlikely to be ABS.
    Quick and easy is to replace master cyclinder. Alternatively drain and remove master cylinder, clean hone and fit new piston and housing seals.
    vs executive
    Jun 2010
    thanks for the time and advice guys, thought it might be a seal in the M.C. i will put it to my girl and get it done. cheers
  1. alright so, brake pedal = parkers on front and rear brake light. head lights on and..
    By budgieVH in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-09-2011, 08:29 PM
  2. Brake pedal occasionally travels to floor
    By 08sky_way in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-11-2010, 08:12 AM
  3. brake lights not coming on until brake pedal almost to floor
    By zskinner in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-10-2010, 07:11 AM
  4. Put Manual Pedal Box In, Now Brake Pedal Is Stiff, Quick Replies Please
    By xtreme_sony in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-06-2009, 09:01 PM
  5. vh 5.0l brake pedal all the way to the floor
    By benny999 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-05-2008, 08:51 PM
