Results 1 to 5 of 5
Thread: Help needed!
    VE SV6, VX Executive II, VS Esteem
    Jun 2010
    Default Help needed!
    hey this arvo i decided to put a new cluster face into my VX all was fine, put the needles back on and after a bit of fiddling got em working except for the fuel gauge one, iv tried 20 odd times off putting it back on at diffrent widths to the face etc and nothing...
    any ideas?
    GSXR1000
    Apr 2010
    WA
    if you put the old one back on does the fuel gauge work?
    If so, perhaps you have an issue with the new cluster ?
    Jun 2010
    i only changed the face, so i took of the needle replaced the face, replaced the needle and now the gauge dont work.....
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    Mick1988's Avatar
    Mick1988 is offline W.A. Cruise Moderator
    Too many to list......
    Apr 2008
    Perth, Western Australia
    Remove the binnacle and install the cluster. Try moving the needle by hand and see if it's stuck. Perhaps you've slightly bent the pin the needle sits on and that has caused for it to rub against the gauge face. Check the plastic sleeve of the needle to make sure you haven't cracked it also. Only other thing to try if both of these check out is a little bit of super glue to make sure the pin isn't slipping inside the sleeve. If all else fails, you've damaged the gauge.
    VX2 Executive Sedan - 3.8L Auto (for now)
    VT SS Sedan - Supercharged V6 Auto (Genuine L67 SS)
    VN SS Sedan - 5.0L 5 Speed Manual (Currently Balga spec waiting for panel and paint)
  1. Help needed
    By WogBoyz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-08-2010, 07:02 PM
  2. help needed please
    By saint_i_aint_1 in forum VT - VX - VU - WH - V2
    Last Post: 23-09-2009, 04:09 AM
  3. Needed!!!!!
    By vh sle !!!!! in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-01-2009, 08:29 PM
