thinking of installing power windows into the front only so using a VU switch. how hard is this to do?
if i remove my centre console the is a plug with nothing connected to it, would this be for the power windows?
i have the executive model if that helps....
It's a fairly easy job to do I've done it successfully multiple times. The front two doors are more difficult to do than the rears. The scissor regulators can be a pain to have to align but it's just something you have to be patient with and maybe have someone to hold the glass for you. The rear ones are really easy I reckon if you're doing the fronts you might as well do the rears too. You will also need the relays and fuses, and don't forget the door trims.
You will need to change the wiring looms inside the doors which plug into the main body harness in the pillars. Being an Executive you most likely have a LOW level BCM and wiring harness. This means that you will need to cut two wires and solder them (don't forget heat shrink) to bypass the driver's window auto down feature.
VX2 Executive Sedan - 3.8L Auto (for now)VT SS Sedan - Supercharged V6 Auto (Genuine L67 SS)VN SS Sedan - 5.0L 5 Speed Manual (Currently Balga spec waiting for panel and paint)
i know this is a fairly old post but could anyone help me out on this..
I'm planing on doing a 2001 VX manual - power window conversion and have been lookin on ebay for parts.
i also had a look at places that could do it for me and one place i emailed got back to me and said this..
"Thank you for your enquiry.
We can only fit front door power windows in the VX , as the supplier does not sell the rear door harnesses.
To get power windows in the fronts it will cost you $650."
WTF?! i found a conversion pack on ebay for $300!! and thats all four windows...
anyone know of someone who may be able to do it for cheaps? cos i dunno if id have the patience for something like this!
