Results 1 to 6 of 6
Thread: P1571 fault code
    vx commdoore
    Nov 2010
    sydney
    Default P1571 fault code
    hi everyone,,, as i mentioned previously in a different thread that am having an engine shudder only at idle and i replaced every single part in car starting from maf sensor all the way down to the fuel filter lolololololo but still shivers or shudder at idle although the car runs perfect...... so this morning the computer throw up this code P1571 i quickly Google it and its comes up as (Traction Control Torque Request Circuit) so plz guys what does that means?????? is this had to do with my current problem????
    thanks
    ashbox's Avatar
    ashbox is offline 6 speed
    VZ SS 6 Spd
    Apr 2007
    The Car
    not sure if it has anything to do with your current problem..
    i just looked up the code in my workshop manual and it sounds like (to me) that your abs and tc aren't sending a signal to to your pcm
    Chev badges are an instant fail
    vx commdoore
    Nov 2010
    sydney
    Quote Originally Posted by ashbox View Post
    thanks mate for the information i just removed the abs and tc plugs cleaned them. check engine light went off straight away.
    ashbox's Avatar
    VZ SS 6 Spd
    Apr 2007
    The Car
    you'll still need to get the fault code cleared, otherwise it'll be there again when you get the computer checked again
    vx commdoore
    Nov 2010
    sydney
    i did clear the code without dis the battery its like to cycle the ignition key 100 times this information from a holden dealer.
    vx commdoore
    Nov 2010
    sydney
    am really ran out of ideas my car drive perfect,except that shudder or shiver at idle replaced alot of parts cost me a fortune including engine and tranny mounts i think am gonna live with it or get used to it.
    today also noticed at idle when i turn on the ac this shudder goes away its really a mystery.
  1. fault code 92
    By tha goviner in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-08-2010, 03:08 PM
  2. Fault Code 22
    By Tom_1569 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-02-2008, 04:35 PM
  3. Fault code 110.......WTF
    By bucketeer in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-01-2006, 09:41 PM
  4. Fault Code Help
    By TigerVX in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-08-2005, 09:08 AM
  5. ECU Fault code
    By TigerVX in forum Electrical Wiring / Questions
    Last Post: 26-07-2005, 05:55 PM
