Results 1 to 8 of 8
Thread: Tie rod warn?
    VT SS 5.7
    Mar 2005
    Goulburn
    Default Tie rod warn?
    Ok vt ss 2000 model, how do I tell if tie rod ends are warn? Ihad a look at the rubber boot on them and they have slight age old cracks, is there any other way to tell when they are warn
    Real cars don't power the front wheels, they lift them
    VB SL/E
    Dec 2008
    Have an assistant turn the steering wheel from side to side while you look at them checking for any play in their movement.
    FWIW they are cheap and piss easy to change if you are handy with tools.
    VT SS 5.7
    Mar 2005
    Goulburn
    Cheers mate, only thing that i have noticed is while the car is sitting still , if i move the steering wheel left and right about 2 inches i can hear a knock assuming its a tie rod end problem since i just replaced the Sway bar link pins with the S shaped ones
    1997 VS COMMODORE,1996 GTS-R COMMODORE
    Feb 2011
    NEWCASTLE
    VB SL/E
    Dec 2008
    Feb 2011
    NEWCASTLE
    VT SS 5.7
    Mar 2005
    Goulburn
    i can only hear the knock on the passengerside of the car front, just brought a set of tie rod ends gonna fit them up in about an hour to see if that fix`s the problem. i also checked the rack bolts
    that goto the Crossmember and them seem tight
    But if all else fails ill replace everything till problem is fixed lol
    VB SL/E
    Dec 2008
    Just make sure you screw the new ones on the same distance as the old ones to keep the toe adjustment correct.
